Dumping suggestions
yschandra
Dumping suggestions
Post by yschandra »
I recently started building my UHD collection, mostly old movies. I got Buffalo BRXL-PUS6U3B as there is a success with this driver. Able go to 1.03 version of BU40N firmware. Now of my collection 12 movies I expected to decrypt at least one movie. All of them failed with "volume key unknown". I checked the guide and verified every thing is in working order internet access etc. Example of one movie dump file I submitted is "MKB20_v61_Blade_Runner_2049_48CB". Just wanted to understand what is going on.
Thanks,
yschandra
MrPenguin
Re: Dumping suggestions
Post by MrPenguin »
yschandra wrote:
Thu Sep 26, 2024 3:38 am
Most likely, new disks have been released after all copies of the old releases have been sold, and MakeMKV likely hasn't seen any copies of the new releases yet. You'll need to email the TGZ dumps that MakeMKV has created to svq@makemkv.com as usual.
As an aside, you can also check whether the keys you need exist in the alternate KEYDB database. In other words, downloading the latest KEYDB.cfg file into MakeMKV's data directory (i.e. the directory were MakeMKV also writes its TGZ dump files) and restarting MakeMKV.
yschandra
Post by yschandra »
Thank you, I will submit the dumps as well as try your suggestion.
MrPenguin
Post by MrPenguin »
yschandra wrote:
Thu Sep 26, 2024 2:19 pm
Check your PM?
yschandra
Post by yschandra »
MrPenguin wrote:
Thu Sep 26, 2024 1:42 pm
I tried keydb.cfg, which did not help.
Thanks,
yschandra
In the logs, do you see any messages like:
HK download failed or disabled
if so, you still have issues with MakeMKV getting the keys.
