Dump submitted: Lord of the Rings Two Towers Extended Pt 2
WhiskingBackspin
Post by WhiskingBackspin »
Seems to be a missing key for Two Towers Pt 2, purchased in Scandinavia September 2021. A bit odd?
Dump submitted: MKB20_v76_The_Lord_of_the_Rings-_The_Two_Towers_(EXT_)_PT_2_694B.tgz
MrPenguin
Re: Dump submitted: Lord of the Rings Two Towers Extended Pt 2
Post by MrPenguin »
WhiskingBackspin wrote: Tue Sep 17, 2024 11:32 am Dump submitted: MKB20_v76_The_Lord_of_the_Rings-_The_Two_Towers_(EXT_)_PT_2_694B.tgz
Have you tried copying the latest KEYDB.cfg file into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?
WhiskingBackspin
MrPenguin wrote: Tue Sep 17, 2024 1:46 pm
I tried to open the disc about 6 hours later and it then worked, I'm not sure why.
