Latest beta 1.17.7
lejeanjean
Latest beta 1.17.7
Post by lejeanjean »
Seems like the latest beta 1.17.7 crashes after startup ? used to work nicely before, but was requested to install a newer one and now it crashes
Re: Latest beta 1.17.7
Did you install the current key? The key in the archive expired already.
MakeMKV is free while in beta
lejeanjean
That helped - the temporary key - however that was never necessary in the past...
Then this is the first time you've experienced a long beta period with MakeMKV. The keys expire after two months, but the beta version doesn't change that often anymore. If you look back through the version history, the gap between new versions has gone up. 1.17.6 lasted for 5 months, before being replaced by 1.17.7, which was just a "Version bump, no changes". That version is now nearly 4 months old, so it's included key expired several months ago.
This key expires at the end of October... Guess what will happen then?
MrPenguin
Post by MrPenguin »
Woodstock wrote:
Wed Sep 11, 2024 12:53 pm
Derp, "Halloween"?? ;)
