Dump file emails
Virtualfryngpan
Dump file emails
Post by Virtualfryngpan »
I submitted 5 dump files for UHD movies to svq@makemkv.com between 8/21/24 & 8/27/24 and the discs still don't work, is the person who usually fixes this on vacation at the moment? Not mad if they are, just curious because it doesn't usually take this long to get it resolved.
Re: Dump file emails
Virtualfryngpan wrote:
Tue Sep 10, 2024 5:40 am
I find that whenever I submit a dump, it takes 2-3 weeks (usually 2) for the key to be added.
MrPenguin
Post by MrPenguin »
Have you tried copying the latest KEYDB.cfg into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and then restarting MakeMKV? KEYDB is an alternative source of keys that MakeMKV can use (if available), and sometimes it can help...
