Dump Submitted - Creepshow 2024 Steelbook
pseudohero
Post by pseudohero » Sun Sep 01, 2024 5:28 pm
File MKB20_v77_Creepshow_4BBC.tgz was submitted!
webprodroid
Re: Dump Submitted - Creepshow 2024 Steelbook
Post by webprodroid » Thu Sep 05, 2024 3:01 am
MKB20_v77_Creepshow_4BBC.tgz also submitted 09/03/2024
MrPenguin
Post by MrPenguin » Thu Sep 05, 2024 9:38 pm
The latest KEYDB.cfg file contains this entry:
0x408A6030F5DBE745914BFA05A1CAF8DF7966368B = CREEPSHOW (Creepshow) | D | 2023-05-09
Does copying this file into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and then restarting MakeMKV help?
webprodroid
Post by webprodroid » Sat Sep 07, 2024 12:29 am
It does not make a difference. I tried that first. This is a new release, just came in from preorder. New transfer this year?
bbraskey67
Post by bbraskey67 » Sat Sep 07, 2024 10:20 pm
Has anyone actually tried to watch their disc on a UHD player? I have the Panasonic DP-UB820 and when I put the disc in, it won't progress past the opening screen that shows brief clips of the movie with the static artwork on the left side of the TV screen. There's no on-screen menu and none of the buttons on my remote will force it to play the movie. It's just stuck on that opening screen. What am I missing? Any suggestions until we can actually rip the disc?
MrPenguin
Post by MrPenguin » Sat Sep 07, 2024 11:31 pm
OK, but KEYDB is updated frequently by people across the Internet. It is worth running
> findvuk synchronize
occasionally to check whether any new entries can help.
webprodroid
Post by webprodroid » Sun Sep 08, 2024 12:30 am
Noted, ill keep trying. ty for your help
> findvuk synchronize
webprodroid
Post by webprodroid » Sun Sep 08, 2024 5:10 am
FYI for anyone else, the latest KEYDB.cfg file downloaded by the FindVUK sync utility had the correct keys and I am able to read the disk with it. The HASH MakeMKV uses by default is not yet updated. Hope this helps! Thanks MrPenguin!
