Dump Submitted - Creepshow 2024 Steelbook
pseudohero
File MKB20_v77_Creepshow_4BBC.tgz was submitted!
webprodroid
Re: Dump Submitted - Creepshow 2024 Steelbook
MKB20_v77_Creepshow_4BBC.tgz also submitted 09/03/2024
The latest KEYDB.cfg file contains this entry:
0x408A6030F5DBE745914BFA05A1CAF8DF7966368B = CREEPSHOW (Creepshow) | D | 2023-05-09-
webprodroid
It does not make a difference. I tried that first. This is a new release, just came in from preorder. New transfer this year?
bbraskey67
Has anyone actually tried to watch their disc on a UHD player? I have the Panasonic DP-UB820 and when I put the disc in, it won't progress past the opening screen that shows brief clips of the movie with the static artwork on the left side of the TV screen. There's no on-screen menu and none of the buttons on my remote will force it to play the movie. It's just stuck on that opening screen. What am I missing? Any suggestions until we can actually rip the disc?
OK, but KEYDB is updated frequently by people across the Internet. It is worth runningwebprodroid wrote: ↑Sat Sep 07, 2024 12:29 amIt does not make a difference. I tried that first. This is a new release, just came in from preorder. New transfer this year?
> findvuk synchronize-
webprodroid
Noted, ill keep trying. ty for your help
MrPenguin wrote: ↑Sat Sep 07, 2024 11:31 pmOK, but KEYDB is updated frequently by people across the Internet. It is worth runningwebprodroid wrote: ↑Sat Sep 07, 2024 12:29 amIt does not make a difference. I tried that first. This is a new release, just came in from preorder. New transfer this year?occasionally to check whether any new entries can help.Code: Select all
> findvuk synchronize
webprodroid
FYI for anyone else, the latest KEYDB.cfg file downloaded by the FindVUK sync utility had the correct keys and I am able to read the disk with it. The HASH MakeMKV uses by default is not yet updated. Hope this helps! Thanks MrPenguin!
