Dump Submitted - Creepshow 2024 Steelbook
pseudohero
Post by pseudohero »
File MKB20_v77_Creepshow_4BBC.tgz was submitted!
webprodroid
Re: Dump Submitted - Creepshow 2024 Steelbook
Post by webprodroid »
MKB20_v77_Creepshow_4BBC.tgz also submitted 09/03/2024
MrPenguin
Post by MrPenguin »
pseudohero wrote:
Sun Sep 01, 2024 5:28 pm
The latest KEYDB.cfg file contains this entry:
0x408A6030F5DBE745914BFA05A1CAF8DF7966368B = CREEPSHOW (Creepshow) | D | 2023-05-09
Does copying this file into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and then restarting MakeMKV help?
webprodroid
It does not make a difference. I tried that first. This is a new release, just came in from preorder. New transfer this year?
bbraskey67
Post by bbraskey67 »
Has anyone actually tried to watch their disc on a UHD player? I have the Panasonic DP-UB820 and when I put the disc in, it won't progress past the opening screen that shows brief clips of the movie with the static artwork on the left side of the TV screen. There's no on-screen menu and none of the buttons on my remote will force it to play the movie. It's just stuck on that opening screen. What am I missing? Any suggestions until we can actually rip the disc?
MrPenguin
Post by MrPenguin »
webprodroid wrote:
Sat Sep 07, 2024 12:29 am
OK, but KEYDB is updated frequently by people across the Internet. It is worth running
> findvuk synchronize
occasionally to check whether any new entries can help.
webprodroid
Noted, ill keep trying. ty for your help
MrPenguin wrote:
Sat Sep 07, 2024 11:31 pm
> findvuk synchronize
webprodroid
FYI for anyone else, the latest KEYDB.cfg file downloaded by the FindVUK sync utility had the correct keys and I am able to read the disk with it. The HASH MakeMKV uses by default is not yet updated. Hope this helps! Thanks MrPenguin!
