Submitted file MKB20_v76_Dracula_AD2F.tgz
Dracula (1931)
DRACULAE1931_UPK1 [Dump]
outland
Re: DRACULAE1931_UPK1 [Dump]
Still can't open this one. Anyone else that have tried this version of Dracula?
Overhead5469
I also have problems with this disc. I submitted the dump about 2 weeks ago and it seems to match the one you have submitted.
Did you get it open or do you still have the same problem?
MakeMKV v1.17.7 win(x64-release) started
Using LibreDrive mode (v01.0 id=489CDFD6D392)
Downloading latest HK to C:\Users\xxx/.MakeMKV ...
Saved AACS dump file as C:\Users\xxx/.MakeMKV/MKB20_v76_Dracula_AD2F.tgz
MrPenguin
The latest KEYDB.cfg file contains these entries:Overhead5469 wrote: Tue Aug 27, 2024 4:38 am I also have problems with this disc. I submitted the dump about 2 weeks ago and it seems to match the one you have submitted.
0x05D0C051E4AFF47A987FAB3F1FCB1B9C106BA94D = DRACULAE1931_UPK1 (Dracula) | D | 2021-08-02
0xC36E242EE63BE8325389A50737E7AB96398F87C9 = DRACULAE1931_UPK1 (Dracula) | D | 2021-08-02
Overhead5469
That did the trick, thank you.MrPenguin wrote: Wed Aug 28, 2024 7:36 amThe latest KEYDB.cfg file contains these entries:Overhead5469 wrote: Tue Aug 27, 2024 4:38 am I also have problems with this disc. I submitted the dump about 2 weeks ago and it seems to match the one you have submitted.Does copying this file into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV help?Code: Select all
0x05D0C051E4AFF47A987FAB3F1FCB1B9C106BA94D = DRACULAE1931_UPK1 (Dracula) | D | 2021-08-02 0xC36E242EE63BE8325389A50737E7AB96398F87C9 = DRACULAE1931_UPK1 (Dracula) | D | 2021-08-02
As a sanity check I checked that I have internet access enabled and tried again without the manually downloaded keydb.cfg but it didn't work.
