The0riginal
Re: SDFtool Flasher
#1111 Post by The0riginal » Tue Aug 27, 2024 3:53 pm
Drive: LG WH14NS40 in a Vantec NST-540S3-BK enclosure
I used the read function to confirm current firmware and the filename contained the following: WH14NS40_1.05_212005061444
I assume that means that my current firmware is encrypted so I check the appropriate setting in the GUI.
I select the 1.02 firmware for my drive and initiate the write function.
I receive the following error: "Command produced error code 0x82052603"
Any ideas?
Re: SDFtool Flasher
#1112 Post by MartyMcNuts » Tue Aug 27, 2024 9:00 pm
The0riginal wrote: Tue Aug 27, 2024 3:53 pm Drive: LG WH14NS40 in a Vantec NST-540S3-BK enclosure
Any ideas?
You don't select anything with regards to the firmware encryption. SDFtool flasher automatically sets the encrypted flag if the drive has encrypted firmware.
Yes, your 1.05 is encrypted so in SDFtool flasher you should see 2 green ✔️, one for drive platform and the other for encrypted firmware.
Also ensure there's no disc in the drive and the tray is closed.
When you say 1.02, are you talking about the recommended WH16NS60 1.02 or the WH14NS40 1.02?? You should flash the former first to remove the firmware encryption. If you want to flash another firmware version afterwards, then you can.
The0riginal
Re: SDFtool Flasher
#1113 Post by The0riginal » Wed Aug 28, 2024 10:26 pm
MartyMcNuts wrote: Tue Aug 27, 2024 9:00 pm When you say 1.02, are you talking about the recommended WH16NS60 1.02 or the WH14NS40 1.02?? You should flash the former first to remove the firmware encryption. If you want to flash another firmware version afterwards, then you can.
Ah that seemed to do the trick. Forgive me if I'm wrong but I didnt see any instruction to first flash WH16NS60 in the case of encrypted factory firmware
Would you recommend keeping the WH16NS60 firmware or flashing it to the model specific firmware once the encryption is removed?
Thank you!
Re: SDFtool Flasher
#1114 Post by MartyMcNuts » Thu Aug 29, 2024 1:44 am
The0riginal wrote: Wed Aug 28, 2024 10:26 pm
Thank you!
If you use MakeMKV for your ripping keep it on WH16NS60 firmware as it reads faster and removes the sleep bug. There's only disadvantages if you flash to the WH14NS40 firmware.
The instructions in the UHD guide thread say this. Just to make it easier, I have added this note to the first post of this thread.
Myluckyday
Re: SDFtool Flasher
#1115 Post by Myluckyday » Sun Sep 01, 2024 12:50 am
Hi Marty,
How are you? Hope you're doing well. My name is Quang and I am a newbie here trying to learn how to flash a firmware to my newly purchase Blu-ray burner. As I did, it cause some unknown error. I greatly appreciate if you or anyone can give me some tip of how to get this done successfully. Please see the attached drive information and the error message.
Thank you,
Quang
Re: SDFtool Flasher
#1116 Post by Billycar11 » Sun Sep 01, 2024 3:11 am
Myluckyday wrote: Sun Sep 01, 2024 12:50 am Hi Marty,
Thank you,
Quang
you have to provide more info
drive and drive fw from makemkv
fw your trying to flash
ect
for lg and asus drives you really should not need assistance its all outlined in the guide see below flashing lg/asus drives has not changed since late 2020 ish
Myluckyday
Re: SDFtool Flasher
#1117 Post by Myluckyday » Sun Sep 01, 2024 5:45 am
Hello Billycar11,
Here's my LG firmware information from MakeMKV:
Product: BD-RE WH16NS40
Revision: 1.05
Serial number: [redacted]
Harware support: Yes
Firmware support: No
Firmware version: 1.05
I am trying to flash the firmware using SDFtool Flasher to replace the current firmware version (1.05) on this drive to a new "DE_LG_WH16NS40-NS50_1.02.bin" that I downloaded from this website in the Zipped folder "All You Need Firmware Pack (MartyMcNuts)". Did I miss any step or do anything wrong here? Please kindly advise! Thank you for your time!
9-10-2024: Latest update regarding my drive.
I want to give you an update of the progress. After many failed attempt, so I almost gave up and thinking of returning this drive. However, after playing a movie the next day, and I tried to flash again. This time it went through and I was able to rip a few Bluray DVD now. However, I couldn't rip Mission Impossible - Fallout. So, I search this site and found some conversation about lower my MakeMKV to version 1.14.1 from 1.17.7. It gave me a warning that this version is too old to run. Then, I reinstalled the version 1.17.7 but this time it didn't run since it said it too old a version. I guess I have to purchase this license even though I only have it ran for like 12 days max. Can anyone advise if this is the case. Thank you.
danmanx
Re: SDFtool Flasher
#1118 Post by danmanx » Sun Sep 01, 2024 3:16 pm
Hi, when I wanted to use sdftool flasher to upgrade my drive (BD-RE WH16NS60) to 1.02 MK, it occurred an error wrote
Command produced error code 0x82000000
Here's the drive information
OS device name: H:
Product: BD-RE WH16NS60
Revision: 1.00
Firmware date: 2117-04-25 17:56
Highest AACS version: 81
Firmware version: 1.00
Could anyone know what's this case?
Also, makemkv shows "LibreDrive Enabled", but when I rip UHD, it shows below, did i mess up something? I can rip UHD discs perfectly through this drive when the keys available.
Debug log started at Sun Sep 01 03:32:34 2024 , written by MakeMKV v1.17.6 win(x64-release)
001005:0000 MakeMKV v1.17.6 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as file://C:\Users\danmanx/MakeMKV_log.txt
SDF  v098: HL-DT-ST_BD-RE__WH16NS60_1.00_211704251756_103HAVN29291
005072:0000 Backing up disc into folder "file://C:/Users/danmanx/Desktop/backup/A moment of romance"
DEBUG: Code 2147483648 at WKYQi`r2nRn]/W8S:121265499
DAFD=PAAAADAAAAEABDQgEFwECAQ==
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..046D3E117CDEE7AAF9A44046B3001C6259E to device 'SPTI:\Device\CdRom2'
001003:0020 DEBUG: Code 0 at (V0PO7]PqU(,OTLVs:213130766
001003:0020 DEBUG: Code 0 at a%48&'jm4Zb*$m{*oY:121263429
001003:0020 DEBUG: Code 0 at a%48&'jm4Zb*$m{*oY:213130789
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..026F8C23267068FB2A99716083A3D39EBD8 to device 'SPTI:\Device\CdRom2'
001003:0020 DEBUG: Code 1 at a%48&'jm4Zb*$m{*oY:213130789
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0475573C54B1FC2785B73A352B8E8B3E52A to device 'SPTI:\Device\CdRom2'
001003:0020 DEBUG: Code 2 at a%48&'jm4Zb*$m{*oY:213130789
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0DCD12CD7EBDB1CF0CBD8A03958889E8516 to device 'SPTI:\Device\CdRom2'
001003:0020 DEBUG: Code 3 at a%48&'jm4Zb*$m{*oY:213130789
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0A53CBA89CBCDF6B681ED113E8256450785 to device 'SPTI:\Device\CdRom2'
001003:0020 DEBUG: Code 4 at a%48&'jm4Zb*$m{*oY:213130789
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..039375979BDAAA6154C81000DA9B88BC0F0 to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0FF8EBE4183D1A0A40446820ADED99FFA78 to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0A5EF9BEC944201741F812EE54C88FB73A1 to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..005474D7A17A13001A297754657E84E51E4 to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0994863DDBD08045E016AD54C8D967DB911 to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..00879EBCDED90FC69F900F4E356437DF38E to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0A85547A9224E886BEA87039881C7A76295 to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..08FF176AA6FDE655CD49AF514CF2C49A0F9 to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..057D053E84902BBB3A430238276850DB202 to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..07FA60C21053D87B70F66AFBA5F33771FF9 to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0181D38BCB8C3C339B8994F8FAA23C6BFA4 to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..036EB91D74EAD0A4A0F7CB7934034008A22 to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0EB6BA898587E432FC0E88EB91E4493CAE4 to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0028FE69F098508EAB9D9E26E3255ECD492 to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..00A076F9F87FB2A798AD182659472B85578 to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0B97B464646D6FFE8A0DE1CB4039AD584D0 to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom2'
DEBUG: Code 0 at (V0PO7]PqU(,OTLVs:213130306
001003:0020 DEBUG: Code 0 at a%48&'jm4Zb*$m{*oY:121264395
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..04FC26F865DC22A8366E145093FB7C13040 to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..026E2656460D753CD85BBD5DCE6E6002647 to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..09A16C104362ECF9FB7CA11E52D3B01E4D5 to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0BF43EB321322FA69D9E6AA8281E0563B10 to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0EFD361A6FDF363D44A6D333D2085CE7036 to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0E0986CC8125C99E128D2E71A09F94F64D5 to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0F50C4471CC43692CF025D03659316625AF to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..03CB1467611425DF74A0AA05539BA9C85BB to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..09B2A7FB9128C0D681299104ED08DF9526D to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0CEDE9B01E534908DD77C29DB723EA51CB3 to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..00B3CA5690CFC99E410D1D6E921C4D0452A to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0F42CC752A8B526C24440426D08E3C3410A to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0DA204053349105C3F0144F9E0E5FB6A1D1 to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..08B6772B9E270270A3FF7D18E2CB635B431 to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..07D0B154D6078559F76ACE3735514511142 to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..075309B0E7AAB73500BAE259FAE0A3BE20E to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0E686668C5492F305F7634417B2F78C2956 to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..05A37398E612E0B7ABF4250F9056ADAFC6F to device 'SPTI:\Device\CdRom2'
002004:0000 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..00200740100720..0FAA815627EAEC1ECA83D0396DAB9B19AAD to device 'SPTI:\Device\CdRom2'
003306:0000 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
Re: SDFtool Flasher
#1119 Post by Billycar11 » Sun Sep 01, 2024 4:46 pm
Myluckyday wrote: Sun Sep 01, 2024 5:45 am Hello Billycar11,
Revision: 1.05
See the downgrade flow chart in my guide it does not recommend that fw flash to wh16ns60 1.02mk
MrPenguin
Re: SDFtool Flasher
#1120 Post by MrPenguin » Sun Sep 01, 2024 6:44 pm
danmanx wrote: Sun Sep 01, 2024 3:16 pm Hi, when I wanted to use sdftool flasher to upgrade my drive (BD-RE WH16NS60) to 1.02 MK, it occurred an error wrote
OS device name: H:
Revision: 1.00
There's this other example of error 0x82000000 here. It suggests that you may need to reconnect your UHD drive to a different SATA port?
danmanx
Re: SDFtool Flasher
#1121 Post by danmanx » Sun Sep 01, 2024 10:32 pm
MrPenguin wrote: Sun Sep 01, 2024 6:44 pm
OS device name: H:
Revision: 1.00
I tried each port :(
ihopnavajo2
Re: SDFtool Flasher
#1122 Post by ihopnavajo2 » Wed Sep 04, 2024 4:05 pm
Welp... I got a new drive to test out and by this point I had forgotten about the warnings of "do not flash desktop drive firmware to a slim drive".
For some reason I thought this flasher was supposed to prevent such silly mistakes.
sgjumper82
Re: SDFtool Flasher
#1123 Post by sgjumper82 » Sun Sep 08, 2024 3:19 am
I am not sure what i am doing wrong with 1 of my drives. I have multiple (HL-DT-ST_BD-RE__WH14NS40). All of the unencrypted flashed.
The 1 encrypted drive I have is Ver 1.05. (W: HL-DT-ST_BD-RE__WH14NS40_1.05_212005061444) and giving me the error of 0xc0000185 when trying to flash with ver. DE_LG_WH16NS60_1.02_MK.bin.
Am i missing something in these posts?
Edit:
I tried the same procedure today, and worked great, not sure what was different.
Ludvik
Re: SDFtool Flasher
#1124 Post by Ludvik » Tue Oct 01, 2024 5:26 pm
hello all, I use dvdfab so i tried to flash my new LGns55 to LGns60_1.00_bin and got error code: 0x82052603.
Any suggestion, please help...
Re: SDFtool Flasher
#1125 Post by Billycar11 » Wed Oct 02, 2024 2:50 am
Ludvik wrote: Tue Oct 01, 2024 5:26 pm hello all, I use dvdfab so i tried to flash my new LGns55 to LGns60_1.00_bin and got error code: 0x82052603.
follow the guide below flashing sequence if its not follow it wont work.
i made it for a reason guys... please read it this has been asked to many times
