Dump Submitted - Kingdom of the Planet of the Apes 4K
FootFungus07
#1 Post by FootFungus07 » Tue Aug 20, 2024 10:05 pm
Kingdom of the Planet of the Apes TGZ Key File:
MKB20_v77_KINGDOM_OF_THE_PLANET_OF_THE_APES_B6C4.tgz
Ralph P.
Re: Dump Submitted - Kingdom of the Planet of the Apes 4K
#2 Post by Ralph P. » Thu Aug 22, 2024 7:45 pm
Same dump file submitted via email and posted to GD. Link has been forward via PM.
hittman1969
#3 Post by hittman1969 » Fri Aug 30, 2024 1:36 am
Can I get in on that link?? Just got 4K and will not rip....
MrPenguin
#4 Post by MrPenguin » Fri Aug 30, 2024 2:28 pm
hittman1969 wrote: Fri Aug 30, 2024 1:36 am Can I get in on that link?? Just got 4K and will not rip....
Have you tried copying the latest KEYDB.cfg into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and then restarting MakeMKV?
#5 Post by dcoke22 » Fri Aug 30, 2024 2:32 pm
A link to download someone else's dump won't help you. That's not how it works.
MakeMKV can defeat the encryption of a DVD or a regular blu-ray. The encryption on 4K UHDs is more complex. MakeMKV has this concept called hashed keys. When you put a 4K UHD into your LibreDrive enabled drive, MakeMKV checks to see if it locally has the hashed key necessary to decrypt the disc. If it doesn't, it goes to the internet to try to download it. If the necessary hashed key isn't available on the internet, it creates a dump file. Users email the dump file to svq@makemkv.com where the dumps are processed and eventually a hashed key is made available. Sometime later, when the 4K UHD is loaded in the drive again, MakeMKV will be able to download the necessary hashed key.
In the mean time, users post the name of the dump file they emailed in. If your disc produces the same dump file name as someone else's disc, they'll need the same hashed key to decrypt. If your dump file name is different, then you'll need a different hashed key. By posting the name of the dump file you emailed in, others can know if their dump file is different and thus should be emailed in.
Tetsujin
#6 Post by Tetsujin » Sat Aug 31, 2024 8:40 pm
I guess my copy maybe had the same dump and Mike has already processed this because I got my disc just yesterday from the big A and it ripped with no issue. Nice!
Sidenote: the split-screen version on the bonus bluray (with pre-vis effects and the actors in mocap suits, etc) is really something special. I'm excited to watch that through with the commentary!
hittman1969
#7 Post by hittman1969 » Sun Sep 01, 2024 9:40 am
MrPenguin wrote: Fri Aug 30, 2024 2:28 pm
I got it working now. Thank you!
tjparasite
#8 Post by tjparasite » Sun Sep 15, 2024 2:10 am
My dump for Kingdom of the Planet of the Apes has a slightly different name...
"MKB20_v77_KINGDOM_OF_THE_PLANET_OF_THE_APES_EF3A.tgz"
Dump was emailed.
Thanks to all for the assistance with this!
MrPenguin
#9 Post by MrPenguin » Sun Sep 15, 2024 10:07 am
tjparasite wrote: Sun Sep 15, 2024 2:10 am MKB20_v77_KINGDOM_OF_THE_PLANET_OF_THE_APES_EF3A.tgz
It's always worth trying the latest KEYDB.cfg file too.
EricLille
#10 Post by EricLille » Fri Sep 20, 2024 11:05 am
I downloaded the new key and copied in the directory
I have the same message "video can’t be decrypted". What should i do now ?
