Kingdom of the Planet of the Apes TGZ Key File:
MKB20_v77_KINGDOM_OF_THE_PLANET_OF_THE_APES_B6C4.tgz
Dump Submitted - Kingdom of the Planet of the Apes 4K
FootFungus07
Re: Dump Submitted - Kingdom of the Planet of the Apes 4K
Same dump file submitted via email and posted to GD. Link has been forward via PM.
hittman1969
Can I get in on that link?? Just got 4K and will not rip....
Have you tried copying the latest KEYDB.cfg into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and then restarting MakeMKV?hittman1969 wrote: Fri Aug 30, 2024 1:36 am Can I get in on that link?? Just got 4K and will not rip....
A link to download someone else's dump won't help you. That's not how it works.hittman1969 wrote: Fri Aug 30, 2024 1:36 am Can I get in on that link?? Just got 4K and will not rip....
MakeMKV can defeat the encryption of a DVD or a regular blu-ray. The encryption on 4K UHDs is more complex. MakeMKV has this concept called hashed keys. When you put a 4K UHD into your LibreDrive enabled drive, MakeMKV checks to see if it locally has the hashed key necessary to decrypt the disc. If it doesn't, it goes to the internet to try to download it. If the necessary hashed key isn't available on the internet, it creates a dump file. Users email the dump file to svq@makemkv.com where the dumps are processed and eventually a hashed key is made available. Sometime later, when the 4K UHD is loaded in the drive again, MakeMKV will be able to download the necessary hashed key.
In the mean time, users post the name of the dump file they emailed in. If your disc produces the same dump file name as someone else's disc, they'll need the same hashed key to decrypt. If your dump file name is different, then you'll need a different hashed key. By posting the name of the dump file you emailed in, others can know if their dump file is different and thus should be emailed in.
I guess my copy maybe had the same dump and Mike has already processed this because I got my disc just yesterday from the big A and it ripped with no issue. Nice!
Sidenote: the split-screen version on the bonus bluray (with pre-vis effects and the actors in mocap suits, etc) is really something special. I'm excited to watch that through with the commentary!
hittman1969
I got it working now. Thank you!MrPenguin wrote: Fri Aug 30, 2024 2:28 pmHave you tried copying the latest KEYDB.cfg into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and then restarting MakeMKV?hittman1969 wrote: Fri Aug 30, 2024 1:36 am Can I get in on that link?? Just got 4K and will not rip....
tjparasite
My dump for Kingdom of the Planet of the Apes has a slightly different name...
"MKB20_v77_KINGDOM_OF_THE_PLANET_OF_THE_APES_EF3A.tgz"
Dump was emailed.
Thanks to all for the assistance with this!
Dump was emailed.
It's always worth trying the latest KEYDB.cfg file too.
I downloaded the new key and copied in the directory
I have the same message "video can’t be decrypted". What should i do now ?
