MEGAN - The volume key is unknown for this disc
Sayjimwoo
Post by Sayjimwoo »
Out of about 100 UHD discs copied. This is the very first one to fail. The dump file is attached.
Using LibreDrive mode (v01.0 id=E9BA8ECC61EF)
Saved AACS dump file as C:\Users\xxx/.MakeMKV/MKB20_v77_M3GAN_AF42.tgz
MrPenguin
Re: MEGAN - The volume key is unknown for this disc
Post by MrPenguin »
Sayjimwoo wrote:
Tue Aug 27, 2024 8:16 pm
You need to email that dump file to svq@makemkv.com.
But in the meantime, the latest KEYDB.cfg file contains these entries:
0x33AE8D89968B358D8F35DBB93A00423E5826128C = M3GAN (M3GAN) | D | 2023-07-10
0xDE8F1B801448E19CA806698530FFD58CBBF92683 = M3GAN (M3GAN) | D | 2023-07-10
0xC7A90D96C3569172DDA36CA8CBB69D0723EF0BCC = M3GAN (M3GAN) | D | 2023-07-10
0xD8395BB2BBE89B44F3B34C95035EDD87ACFCD2FD = M3GAN (M3GAN) | D | 2023-07-25
Does copying this file into MakeMKV's data directory (i.e, where MakeMKV also writes its TGZ dump files) and then restarting MakeMKV help?
Sayjimwoo
Post by Sayjimwoo »
Thank you so very much. I emailed over my dump file and downloaded the latest KEYDB.cfg file, which works perfectly. I am currently ripping MEGAN as I type. Thanks again :)
That dump has been submitted before, in February and in March and November, 2023. I'm surprised it wasn't available.
https://forum.makemkv.com/forum/viewtopic.php?f=12&t=32530
https://forum.makemkv.com/forum/viewtopic.php?f=12&t=33256
https://forum.makemkv.com/forum/viewtopic.php?f=12&t=33422
I'm glad it worked for you with the KEYDB.cfg. It is curious that no hashed key seems to be available.
