Post by MartyMcNuts » Mon Aug 26, 2024 10:09 pm
766875 wrote: Mon Aug 26, 2024 8:44 pm I did and successfully flashed to 1.03. Unfortunately it still won't read my discs, it just ejects them even although it's patched. I tried doing the next flash but it failed.
Product: BD-RE BP50NB40
Revision: 1.03
Serial number: SIM2221124041
Highest AACS version: 81
Firmware version: 1.03
Reading input file /Users/xxx/Downloads/Hybrid_Firmware_for_BP50NB40_to_BP60NB10/DE_LG_BP60NB10_1.00_MK_HBD.bin
Flashing flags = 0x1 : 0 0 0 1 : ---- ---- ---- BOOT
Current Drive ID: HL-DT-ST_BD-RE_BP50NB40_1.03_212005070917_SIM2221124041
Using USB chipset workaround for Desktop drive handshake
yes
  98% .................................................
Write DRAM NG 05/26/02
Command produced error code 0x82052602
You've only done half the job! Now you need to do the cross-flash.
766875
Post by 766875 » Tue Aug 27, 2024 1:36 am
MartyMcNuts wrote: Mon Aug 26, 2024 10:09 pm
Revision: 1.03
yes
I thought that's what I was trying to do with the following line, but I got the error shown above? I didn't think I needed enc after the first flash.
./makemkvcon f -d '/IOBDServices/0AC881AF' -f /Users/xxx/Downloads/sdf.bin rawflash full main -i /Users/xxx/Downloads/Hybrid_Firmware_for_BP50NB40_to_BP60NB10/DE_LG_BP60NB10_1.00_MK_HBD.bin
Post by Billycar11 » Tue Aug 27, 2024 1:42 am
766875 wrote: Tue Aug 27, 2024 1:36 am
Revision: 1.03
yes
please just follow the guide if you want individual help our emails are here
you have to flash bp50 2 times then the hybrid for NB52
or marty's recovery method both work
Post by MartyMcNuts » Tue Aug 27, 2024 3:18 am
Revision: 1.03
yes
Yep, as Billy said, either follow this guide or use the recovery method of SDFtool Flasher: viewtopic.php?p=94848#p94848
I also recommend BU40N 1.00 firmware over the BP60NB10 MK firmware as it is compatible with all good ripping software.
Monstro
Post by Monstro » Fri Aug 30, 2024 5:53 am
Hi there. I'm doing this for the first time and just wanted to make sure I have a compatible drive. I got an LG BH16NS40 manufactured in April of 2024. Will this work, or is it back to the shop for this one?
liamtoh1
Post by liamtoh1 » Fri Aug 30, 2024 1:38 pm
Monstro wrote: Fri Aug 30, 2024 5:53 am Hi there. I'm doing this for the first time and just wanted to make sure I have a compatible drive. I got an LG BH16NS40 manufactured in April of 2024. Will this work, or is it back to the shop for this one?
As per the 1st post of this thread, you should be good if all the requirements are met. Please read and report back with specific questions.
visiter555
Post by visiter555 » Sun Sep 01, 2024 11:21 pm
I have been using an LG BH12LS38 for BluRays, DVDs and CDs for 13 years and it has been rock steady for ripping. Now I have a few UHDs I am wondering if this is UHD friendly?
I have a couple of these that are all on 2011 firmware, so I am good on the non UHDs for quite a long time.
Post by Woodstock » Mon Sep 02, 2024 4:08 am
An LG from 4+ years before UHD came out? Not likely. There are some Pioneers from before 2016 that can be modified, but ...
visiter555
Post by visiter555 » Wed Sep 04, 2024 4:27 pm
I have CD drives that were before DVDs and the actually read and play DVDs with a newer firmware. Of course cables and adapters are necessary. So many manufacturers dropped there "products" when they were to costly for them to produce at the price they wanted. I have two DVDs from Toshiba that are IDE and run like a charm. Of course I have cleaned lenses and belts and so on.
You would be amazed at how things that are "...said can't be done" that can be done.
in 2023 I needed to access a 5 1/4" floppy and was told it is impossible to run on a new computer. Easy as pie on a 2020 Dell Precision workstation.
Been in the IT business since 1982 and you would be amazed things that can be done.
So, the lesson I have experienced is - always try, try and try before your quit.
Post by Coopervid » Fri Sep 06, 2024 12:12 pm
visiter555 wrote: Sun Sep 01, 2024 11:21 pm I have been using an LG BH12LS38 for BluRays, DVDs and CDs for 13 years and it has been rock steady for ripping. Now I have a few UHDs I am wondering if this is UHD friendly?
The chip in your drive is not capable to handle UHDs. So you need a new drive for UHDs.
Hambo
Post by Hambo » Thu Sep 12, 2024 11:27 pm
Worked great!
Simon514
Post by Simon514 » Wed Sep 18, 2024 12:42 am
I haven't read the 162 pages (sorry!) but at the very beginning of the thread it says that Pioneer drives are much better than LG and Asus...
I am curious to know what does much better actually means here?
Post by Billycar11 » Wed Sep 18, 2024 1:23 am
Simon514 wrote: Wed Sep 18, 2024 12:42 am I haven't read the 162 pages (sorry!) but at the very beginning of the thread it says that Pioneer drives are much better than LG and Asus...
its hard to describe but
they dont require reboot when they go into a weird mode usually from a hard to read disc.
they dont just give junk data when they hit a hard to read spot on a disc aka hash errors a pioneer can retry to read a spot lg cant because they give fake data ruining the whole rip and erroring out makemkv.
there lasers usually dont die.
they are much quieter
they seem to last longer.
alot more too but you get the idea
Simon514
Post by Simon514 » Wed Sep 18, 2024 4:17 am
Billycar11 wrote: Wed Sep 18, 2024 1:23 am
Thank you very much for that.
Since I often buy used discs and borrow out of print movies from the library, what you're saying is I will be better buying a Pioneer drive for less than pristine discs to rip... They seem harder to find in Canada though...
Again, thank you Monsieur!
Post by Billycar11 » Wed Sep 18, 2024 5:56 am
Simon514 wrote: Wed Sep 18, 2024 4:17 am
yes they are better at reading hard to read disc but please make sure your discs are clean before you put them in with used ones.
been getting alot of emails lately about this and then they either have to take the drive apart or they send it to me for a cleaning and thats not covered by warranty as its abuse
