Dump Submitted - Drive (2011) 4K
TheEvilMayor
Post by TheEvilMayor »
Dump file is: MKB20_v77_DRIVE_2011_70E8.tgz
MrPenguin
Re: Dump Submitted - Drive (2011) 4K
Post by MrPenguin »
TheEvilMayor wrote: Thu Aug 22, 2024 11:38 pm Dump file is: MKB20_v77_DRIVE_2011_70E8.tgz
The latest KEYDB.cfg contain this entry:
0x4355FAC6731BF325F67DEF8AEACAD2FA428BF745 = DRIVE_2011 (Drive (2011) - 4K Ultra HD) | D | 2024-06-06
Does copying this file into MakeMKV's data directory (i.e. where MakeMKV also writes its dump files) and then restarting MakeMKV help?
TheEvilMayor
MrPenguin wrote: Fri Aug 23, 2024 6:59 am
Huh, that worked. The only reason I didn't try grabbing the latest keydb.cfg file earlier is that when I try to go to the link using chrome it throws me a 404 error. Working on firefox, though.
MrPenguin
Post by MrPenguin »
TheEvilMayor wrote: Mon Aug 26, 2024 8:45 pm Huh, that worked. The only reason I didn't try grabbing the latest keydb.cfg file earlier is that when I try to go to the link using chrome it throws me a 404 error. Working on firefox, though.
Does chrome default to HTTPS these days?
Yes, the default for Chrome is HTTPS, unless you explicitly type HTTP... and then it just does it anyway.
TheEvilMayor
Even when I try to force it to HTTP, it's still giving me a 404 error on this computer. But my other laptop opens the link just fine. I probably need to clear the cache or something.
Post by SamuriHL »
You now have to add exclusions in Chrome to force http.
Sent from my SM-S928U1 using Tapatalk
