Dump Submitted - Drive (2011) 4K
TheEvilMayor
Post by TheEvilMayor »
Dump file is: MKB20_v77_DRIVE_2011_70E8.tgz
MrPenguin
Re: Dump Submitted - Drive (2011) 4K
Post by MrPenguin »
TheEvilMayor wrote:
Thu Aug 22, 2024 11:38 pm
The latest KEYDB.cfg contain this entry:
0x4355FAC6731BF325F67DEF8AEACAD2FA428BF745 = DRIVE_2011 (Drive (2011) - 4K Ultra HD) | D | 2024-06-06
Does copying this file into MakeMKV's data directory (i.e. where MakeMKV also writes its dump files) and then restarting MakeMKV help?
TheEvilMayor
MrPenguin wrote:
Fri Aug 23, 2024 6:59 am
Huh, that worked. The only reason I didn't try grabbing the latest keydb.cfg file earlier is that when I try to go to the link using chrome it throws me a 404 error. Working on firefox, though.
MrPenguin
Post by MrPenguin »
TheEvilMayor wrote:
Mon Aug 26, 2024 8:45 pm
Does chrome default to HTTPS these days?
Yes, the default for Chrome is HTTPS, unless you explicitly type HTTP... and then it just does it anyway.
TheEvilMayor
Even when I try to force it to HTTP, it's still giving me a 404 error on this computer. But my other laptop opens the link just fine. I probably need to clear the cache or something.
Post by SamuriHL »
You now have to add exclusions in Chrome to force http.
Sent from my SM-S928U1 using Tapatalk
