JFK 4K Director's Cut not loading
philb1701
Post by philb1701 »
JFK 4K UHD is almost a month old now and the codes are still not loading.
logic
Re: JFK 4K Director's Cut not loading
Post by logic »
Reviving this, looks like the Shout Select box set I received has a different AACS dump for the 4K disc.
Submitted MKB20_v77_JFK-_Director's_Cut_5A92.tgz yesterday.
MrPenguin
Post by MrPenguin »
logic wrote:
Thu Aug 22, 2024 5:39 pm
The latest KEYDB.cfg contains this entry:
0x1147B2EBC7E81AF663FB31288B10C2CCB5510C62 = JFK_DIRECTORS_CUT (JFK: Director's Cut) | D | 2023-10-24
Does copying this file into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and then restarting MakeMKV help?
logic
Post by logic »
Nope. (I use FindVUK to keep keydb.cfg up to date, and it's got the entry you mentioned, along with another version as well.)
But, submitted the dump to svq@, so I'll just wait until it's updated.
