The Boy 4K
BrianDW
The Boy 4K
The Boy 4K Scream Factory 2024
24EA dump submitted
24EA dump submitted
MrPenguin
Re: The Boy 4K
The latest KEYDB.cfg file contains this entry:
0x80D32FE5C2B83CF8A577586B82B85E2378BF34A3 = THE_BOY (The Boy)-
BrianDW
Re: The Boy 4K
What File?
Isn't a file.
I copied it into the keydb.cfg and nothing happened.
Sorry, but my technical know-how is limited.
Isn't a file.
Re: The Boy 4K
KEYDB.cfg IS the file. Copy it into the MakeMKV data directory & restart MakeMKV. Try the disc again.BrianDW wrote: Wed Aug 21, 2024 10:56 pm What File?
Isn't a file.
MrPenguin
Re: The Boy 4K
The KEYDB.cfg file is updated regularly. It sounds like you need a new version, i.e. one that contains a line starting with:
BrianDW
Re: The Boy 4K
What am I supposed to copy and paste?
The line provided is just a line of text, not a file.
ryley
Re: The Boy 4K
You can download the keydb from the page linked by both MrPenguin and d00zah. If navigating to a web page is confusing, here is a direct link: This is a clickable link to download the keydbBrianDW wrote: Thu Aug 22, 2024 2:40 am What am I supposed to copy and paste?
When you download the keydb, it will be a zip file. You will need to extract or "unzip" this file. I know it sounds overwhelming but don't worry - your computer can unzip it for you.
If you manage to unzip the file post an update here and we'll try to walk you through the next steps. Just a heads up: it'll involve cutting and pasting but you won't need any scissors. Crazy stuff...
Don't worry, the keydb is freeBrianDW wrote: Thu Aug 22, 2024 2:42 am Doesn't work for me.
I don't know what any of this malarky MEANS.
I paid for MakeMKV
When I pay for software, I expect it to work JUST BY RUNNING IT.
MrPenguin
Re: The Boy 4K
The KEYDB is not part of MakeMKV. It is an optional, external resource that MakeMKV can use, potentially allowing you to unlock your disks faster than by otherwise waiting for svq@makemkv.com to generate a new hashed key.
You are free either to use or not use KEYDB, irrespective of any licence you have purchased for MakeMKV. However, AFAIK the time it takes for svq@makemkv.com to provide new hashed keys has always been both unknown and unknowable, even for licensed users.
BrianDW
Re: The Boy 4K
I know how to downlaod and unzip files.
What you provided was a string of text and a link to a site with no search option.
Thanks for your efforts. in any event.
MrPenguin
Re: The Boy 4K
I haven't used Windows for many years, but if you click on a link to a ZIP file then doesn't Windows download that ZIP file automatically? And when you click / double-click on that ZIP file, then doesn't Windows open it for you to reveal the KEYDB.cfg inside?BrianDW wrote: Thu Aug 22, 2024 11:52 am I know how to downlaod and unzip files.
BrianDW
Re: The Boy 4K
The Boy works with MAKE MKV now.
I downloaded and unzipped the file with 7zip.
Added the key you provided, and it works.
Thank you.
Thank you.
ryley
Re: The Boy 4K
Great to hear you got it working. Just remember that the keydb is usually updated several times a day, so you may need to periodically re-download it to get support for the latest titles.BrianDW wrote: Thu Aug 22, 2024 12:08 pm The Boy works with MAKE MKV now.
Thank you.
MrPenguin
Re: The Boy 4K
Have you also tried "Bob Le Flambeur" and "You're Next"?BrianDW wrote: Thu Aug 22, 2024 12:08 pm I downloaded and unzipped the file with 7zip.
