Dump Submitted - Chinatown (1974) 4K 1-Disc New Zealand Edition
Pete B
#1 Post by Pete B » Wed Aug 21, 2024 10:46 pm
Hi everyone
My 1-Disc New Zealand release of Chinatown (1974) 4K just arrived and I got the message below so have submitted the tgz.
MakeMKV v1.17.7 win(x64-release) started
Using LibreDrive mode (v06.3 id=4ACF8047C3AC)
Evaluation version, 28 day(s) out of 30 remaining
Saved AACS dump file as C:\Users\peter/.MakeMKV/MKB20_v77_Chinatown_6C92.tgz
zittrig
Re: Dump Submitted - Chinatown (1974) 4K 1-Disc New Zealand Edition
#2 Post by zittrig » Wed Sep 18, 2024 3:05 pm
Same here with the German disc. :(
MrPenguin
#3 Post by MrPenguin » Wed Sep 18, 2024 3:09 pm
zittrig wrote: Wed Sep 18, 2024 3:05 pm Same here with the German disc. :(
The latest KEYDB.cfg file contains these entries:
0x259ACDBA3AFBCF52E1B02C1AF0272200CFB50728 = CHINATOWN (Chinatown) | D | 2024-04-10
0xF9DB2637E16DBB1FFCBF990849C4474445976348 = CHINATOWN (Chinatown) | D | 2024-04-10
0x7E4FFD7A6DD9EF9DBA466930D2D0818F50C5A90A = CHINATOWN (Chinatown) | D | 2024-03-21
Does copying this file into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV help?
zittrig
#4 Post by zittrig » Wed Sep 18, 2024 3:35 pm
You mean, copy the code into the editor and save it as keydb.cfg? That was no help, sorry but thanks a lot! :(
Ah, stop, the .cfg is for download. Sorry :D But saving the whole .cfg is also no solution.
MrPenguin
#5 Post by MrPenguin » Wed Sep 18, 2024 3:54 pm
zittrig wrote: Wed Sep 18, 2024 3:35 pm Ah, stop, the .cfg is for download. Sorry :D But saving the whole .cfg is also no solution.
Yes, you would need to download the entire KEYDB.cfg file, which is distributed inside a ZIP file. I was simply pointing out that it currently contains 3 entries for Chinatown. One of these might be for your disk...?
Pete B
#6 Post by Pete B » Mon Sep 23, 2024 9:28 pm
Confirming successful ripadeedoodaa of the NZ 4K.
Thanks team!
