Pioneer BDR-XD08B
Psycomo
Re: Pioneer BDR-XD08B
Post by Psycomo » Sun Aug 11, 2024 7:55 pm
Awesome. Worked like a champ.
Post by Coopervid » Sun Aug 11, 2024 8:35 pm
Psycomo wrote: Sun Aug 11, 2024 7:55 pm Awesome. Worked like a champ.
I knew. Happy ripping!
b7se4RTD
Post by b7se4RTD » Thu Aug 15, 2024 3:31 pm
Is It possible to cross-flash my device as well ? (and have access to libredrive maybe ?)
Informations lecteur
Nom du lecteur SE : E:
Fabricant : PIONEER
Produit : BD-RW BDR-XD08
Révision : 1.00
Numéro de série : [redacted]
Date micrologiciel : 2022-04-03
Marqueurs d'encryptage bus : 1B
Drive platform: Pioneer RS9330
Firmware version: GENE
Post by Coopervid » Fri Aug 16, 2024 9:18 am
b7se4RTD wrote: Thu Aug 15, 2024 3:31 pm Is It possible to cross-flash my device as well ? (and have access to libredrive maybe ?)
Fabricant : PIONEER
Révision : 1.00
PM sent.
b7se4RTD
Post by b7se4RTD » Fri Aug 16, 2024 11:17 am
Perfect, works as intended with Libredrive as well :)
Thanks a lot !
clgsouza
Post by clgsouza » Sun Aug 18, 2024 12:06 pm
Would it work with the BRD-XD08 1.02?
Post by Coopervid » Sun Aug 18, 2024 5:11 pm
clgsouza wrote: Sun Aug 18, 2024 12:06 pm Would it work with the BRD-XD08 1.02?
Most likely not. I guess your firmware is dated Dec. 22 or newer. Check your Makemkv info.
clgsouza
Post by clgsouza » Sun Aug 18, 2024 9:27 pm
Coopervid wrote: Sun Aug 18, 2024 5:11 pm Most likely not. I guess your firmware is dated Dec. 22 or newer. Check your Makemkv info.
OS device name: E:
Manufacturer: PIONEER
Product: BD-RW BDR-XD08
Revision: 1.02
Serial number: [redacted]
Firmware date: 2022-12-27
Highest AACS version: 68
No love then, huh? It's okay, thank you for your help!
Post by Coopervid » Mon Aug 19, 2024 9:27 am
clgsouza wrote: Sun Aug 18, 2024 9:27 pm
OS device name: E:
Revision: 1.02
It's a pity.
kilolimaalpha
Post by kilolimaalpha » Sun Sep 15, 2024 6:39 pm
I have one on order as well, can I ask for instruction to cross flash this drive? -Thanks!!
MrPenguin
Post by MrPenguin » Sun Sep 15, 2024 7:24 pm
kilolimaalpha wrote: Sun Sep 15, 2024 6:39 pm I have one on order as well, can I ask for instruction to cross flash this drive? -Thanks!!
The same advice applies: check its firmware date. Firmware dated Dec 2022 or newer cannot be either cross-flashed or downgraded.
hwrd69
Post by hwrd69 » Mon Dec 23, 2024 9:40 pm
I currently have a Pioneer BDR-XD08B with 1.02 FW that says that LibreDrive is possible, but not enabled (see Drive info)
Revision: 1.02
Serial number: redacted
Highest AACS version: 76
Is it possible to enable LibreDrive on this device? I can not find clear info which states one way or another. Thanks for any responses.
Post by MartyMcNuts » Tue Dec 24, 2024 1:36 am
hwrd69 wrote: Mon Dec 23, 2024 9:40 pm I currently have a Pioneer BDR-XD08B with 1.02 FW that says that LibreDrive is possible, but not enabled (see Drive info)
Revision: 1.02
No, not currently as the firmware is Dec 2022. Pioneer drives with firmware from 01 Dec 2022 onwards cannot currently be downgraded/cross-flashed nor have LiberDrive enabled.
SoaringLeaf
Post by SoaringLeaf » Mon Jan 27, 2025 5:36 am
Coopervid wrote: Sun Aug 11, 2024 8:35 pm
Turns out I have the exact same drive and fw as Psycomo, mfd Nov 2022. Info below, but looking to crossflash to read UHD discs -- Coopervid, pretty please? :D
Revision: 1.01
Serial number: [...]
Firmware date: 2022-10-11
Highest AACS version: 75
Drive platform: RS9330
Firmware name: PIONEER BDR-BDS8
Firmware version: 1.01
Post by Coopervid » Mon Jan 27, 2025 9:27 pm
SoaringLeaf wrote: Mon Jan 27, 2025 5:36 am
Revision: 1.01
I'm out for now "thanks" to another one-time-poster. Ask Marty or Billy and pay your share they ask for.
