Failed to rip Avatar 1 and 2 UHD Collector's Editions and Warcraft - The Begining UHD
I've started building a 4k movies collection and I wanted to rip them on my PC to have a backup (in case something happened to the discs I purchased).
The rips failed and I was hoping if you could help me please identify the problem.
I have Verbatim External slimline Blu-ray Writer, connects via USB-C, product code: 43888
I am using Windows 10
Other info: I've ripped successfully my collection of documentaries, which contains DVDs, Blu ray and UHD Blu ray. I even purchased a MakeMKV license, the program worked great for these!
The info I get in MakeMKV:
OS device name: G:
Manufacturer: PIONEER
Product: BD-RW BDR-UD04
Revision: 1.14
Serial number: [redacted]
Firmware date: 2020-06-15
Highest AACS version: 77
Drive platform: RS8A10
Firmware version: 1.14
I've tried to rip 3 UHD movies (the only ones I have so far: Avatar 1 and 2 UHD Collector's Edition, Warcraft - The Begining UHD) and none worked, all attempts finished with the error:
MakeMKV v1.17.7 win(x64-release) started
Using LibreDrive mode (v01.0 id=489CDFD6D392)
Saved AACS dump file as C:\Users\abcdef/.MakeMKV/MKB20_v61_Warcraft_C549.tgz
I did some research and tried the folowing:
I checked in MakeMKV, Internet access is enabled.
keydb.cfg:
I got the keydb.cfg file, I have the latest version, I copied the file in C:\Users\abcdef\.MakeMKV. I found that I also have it in the directory C:\Users\abcdef\AppData\Roaming\aacs.
I saw some mentions regarding the file being case sensitive, so I renamed it to a couple of variants like keydb.cfg, Keydb.cfg, KEYDB.cfg. The file is 51.9 mb large, so I presume it has keys. As far as I understood, this shouldn't actually be needed, right?
I also submitted the AACS dump file to svq@makemkv.com last month.
Not really sure where to go from here. Any pointers / advice please? Thank you!
OS device name: G:
Revision: 1.14
keydb.cfg:
Re: Failed to rip Avatar 1 and 2 UHD Collector's Editions and Warcraft - The Begining UHD
Hopefully you found the UHD FAQ.
After you've submitted the .tgz file via email, you will not get a notification that a hashed key is available. Just wait a week or two and try again. If the hashed is available, MakeMKV will download it and the disc will decrypt.
The KEYDB.cfg file is not necessary, but can be useful alternative source of decryption keys. You'll need to keep it up-to-date yourself, but the FindVUK program also has a "synchronize" option which keeps the copy in "C:\Users\abcdef\AppData\Roaming\aacs" aligned with the online database without you needing to redownload the entire file each time.Nightwish wrote: ↑Fri Aug 16, 2024 9:16 pmkeydb.cfg:
Windows file-systems are not case-sensitive. On MacOS and Linux, the file should be named KEYDB.cfg.
See this post for more information.
Yes, thanks, I found UHD FAQ, and there it states the following:dcoke22 wrote: ↑Sat Aug 17, 2024 1:12 pmHopefully you found the UHD FAQ.
" I submitted a dump, how long does it take?
Once submitted, the turnaround can be pretty fast, between 12 to 48 hours. However, it can also sometimes take several days or longer. "
Of course I wasn't expecting it to be solved in a day, but since it's about 3 weeks since I submitted, I thought maybe there are other problems that prevent me from ripping those movies. That's why I posted this thread.
It's understandable that there are no e-mail replies or other notifications, I can only imagine the amount of requests that are received.
If it's just a matter of waiting for the keys, then I'll wait. I only wanted to make sure that the rest is ok.
Yeah, that's what I understood from the forums as well, that the keydb.cfg is not mandatory, but it might be useful in some situations. I thought that I could try it since I've seen that it worked for some people. I did use the latest version of the file.MrPenguin wrote: ↑Sat Aug 17, 2024 2:28 pmThe KEYDB.cfg file is not necessary, but can be useful alternative source of decryption keys. You'll need to keep it up-to-date yourself, but the FindVUK program also has a "synchronize" option which keeps the copy in "C:\Users\abcdef\AppData\Roaming\aacs" aligned with the online database without you needing to redownload the entire file each time.
I wasn't sure if it's case sensitive, I just wanted to try everything I could before posting something and asking for help
It looks like I should just wait for the keys and keep trying periodically.
At any point have you noticed in the MakeMKV log an entry stating "HK download disabled or failed"?Nightwish wrote: ↑Fri Aug 16, 2024 9:16 pmI've started building a 4k movies collection and I wanted to rip them on my PC to have a backup (in case something happened to the discs I purchased).
OS device name: G:
Revision: 1.14
keydb.cfg:
The only log files I could find were the ones in the dump files archives that were generated after trying to rip the movies.MartyMcNuts wrote: ↑Sat Aug 17, 2024 10:41 pm
There is no mention about "HK download disabled or failed" or anything close to that.
The logs have only some software and hardware info, the first steps MakeMKV took in the process and a debug code.
Something drew my attention though, from the log file: "Network access is ENABLED, CURL version 7.72.0/Schannel/1.41.0 (x86_64-pc-win32) , proxy server not set."
Is it enough to have the option enabled or do I need a proxy server as well?
I'm not takling about any log file. I'm talking about the log window at the bottom of MakeMKV. You need to try ripping the disc then copy and paste that log here after you get whatever errors you are talking about.Nightwish wrote: ↑Sun Aug 18, 2024 8:27 amThe only log files I could find were the ones in the dump files archives that were generated after trying to rip the movies.MartyMcNuts wrote: ↑Sat Aug 17, 2024 10:41 pm
Oh, I see. Then it's the one I already posted in the initial thread. I get the same thing every time I try to rip an UHD movie disc
So just email the dump file to svq@makemkv.com if you haven't already and wait for the key to be added. Usually it takes a few weeks.Nightwish wrote: ↑Sun Aug 18, 2024 9:29 amOh, I see. Then it's the one I already posted in the initial thread. I get the same thing every time I try to rip an UHD movie disc
Yes, I did email all 3 dump files. I will waitMartyMcNuts wrote: ↑Sun Aug 18, 2024 12:50 pmSo just email the dump file to svq@makemkv.com if you haven't already and wait for the key to be added. Usually it takes a few weeks.
Even if the latest KEYDB.cfg file doesn't contain entries with VUKs for any of your disks, it is still likely to contain entries with Unit Keys. These would allow you to decrypt your disks by using Xreveal with MakeMKV.
See these instructions for how to use MakeMKV and XReveal together, although I've never tried doing this myself. (It's a "Windows only" thing...).
Edit: Do you have FindVUK installed? Because if so, you could try executing:
> findvuk validateDisc drive=<your-uhd-drive-letter>Code: Select all
Disable_Bus_Encryption_Cmd = "C:\Program Files (x86)\MakeMKV\makemkvcon.exe" info dev:$DRIVE$Re: Failed to rip Avatar 1 and 2 UHD Collector's Editions and Warcraft - The Begining UHD
Thanks for the advice, I managed to get XReveal to work, it decrypted all 3 of my discs and tried to rip them with MakeMKV, just like in instructions. All 3 failed to copy at one point because of read errors:MrPenguin wrote: ↑Sun Aug 18, 2024 1:50 pmEven if the latest KEYDB.cfg file doesn't contain entries with VUKs for any of your disks, it is still likely to contain entries with Unit Keys. These would allow you to decrypt your disks by using Xreveal with MakeMKV.
"Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00213.m2ts' at offset '2454434611" - for the Warcraft disc
"The source file '/BDMV/STREAM/00103.m2ts' is corrupt or invalid at offset 767176704, attempting to work around" - around 600 of these for Avatar 1 and about 1000 for Avatar 2.
The discs are brand new, cleaned and unscratched. Besides, I watched all 3 movies on my TV, they worked (although I couldn't notice if they skipped some frames because disc errors). Maybe I should get a new drive, meh
I don't have it installed, but I will try the steps you wrote and will tell you afterwards.MrPenguin wrote: ↑Sun Aug 18, 2024 1:50 pmEdit: Do you have FindVUK installed? Because if so, you could try executing:to check whether any Unit Key for your disk in the KEYDB.cfg file were actually correct. You would first need to update your FindVUK.ini file:Code: Select all
> findvuk validateDisc drive=<your-uhd-drive-letter>assuming this is where you have installed MakeMKV.Code: Select all
Thank you!
It seems odd that all three would have read errorsNightwish wrote: ↑Sun Aug 18, 2024 5:42 pmThanks for the advice, I managed to get XReveal to work, it decrypted all 3 of my discs and tried to rip them with MakeMKV, just like in instructions. All 3 failed to copy at one point because of read errors:
I'm generally a magnet for strange things and events
Yeah, indeed it's weird, especially since the discs I bought were brand new and sealed. 3 out 3 to have manufacturing errors is next level coincidence
The drive is powered via the USB-C port.
