Randy Magnum
#1 Post by Randy Magnum » Thu Aug 15, 2024 9:09 am
I have no problem with my drive on my Mac. I cannot get MakeMKV working on my Unraid server. I get the following errors:
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SG:dev_21:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..03F to device 'SG:dev_21:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..07F to device 'SG:dev_21:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..07F to device 'SG:dev_21:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0BF to device 'SG:dev_21:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0BF to device 'SG:dev_21:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0FF to device 'SG:dev_21:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0FF to device 'SG:dev_21:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SG:dev_21:0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SG:dev_21:0'
Downloading latest HK to /home/nobody/.MakeMKV ...
Saved AACS dump file as /home/nobody/.MakeMKV/MKB20_v72_The_Goonies_4C0B.tgz
I'm at a loss. I've tried many different configurations with MakeMKV, but haven't been able to figure it out. Thanks in advance.
segfaulted
Re: Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive
#2 Post by segfaulted » Thu Aug 15, 2024 8:11 pm
Are you running MakeMKV from a docker container or some other sandbox? Make sure you've configured it so your blu-ray drive's /dev/sg* device is accessible to the app.
Randy Magnum
#3 Post by Randy Magnum » Thu Aug 15, 2024 8:36 pm
"Are you running MakeMKV from a docker container or some other sandbox?"
I'm running the jlesage docker container.
"Make sure you've configured it so your blu-ray drive's /dev/sg* device is accessible to the app."
I have definitely done this. I've tried making my own device variable. I've tried entering my devices in the Extra Parameters.
During my sleuthing I found some information about a KEYDB.cfg file. I can't seem to find this file anywhere in my app config directory. Could this be the problem?
MrPenguin
#4 Post by MrPenguin » Thu Aug 15, 2024 10:11 pm
The KEYDB.cfg file is an optional resource that MakeMKV can use, if it's present in MakeMKV's data directory. I don't believe it's your problem because not having one is MakeMKV's default configuration.
Having said that, installing one might help if MakeMKV cannot access the network from within your Docker container.
Just checking, but does your drive support LibreDrive? AFAIK MakeMKV cannot use a host certificate to obtain a VID for AACSv2 because it doesn't have such a certificate in the first place. This is why LibreDrive support is mandatory!
segfaulted
#5 Post by segfaulted » Thu Aug 15, 2024 11:17 pm
I'm not sure what you mean by "making" a variable. Can you elaborate?
You have to identify an existing sg* device using a command like lsscsi -g
OP said the drive works fine on a Mac, so this is probably a local config issue.
MrPenguin
#6 Post by MrPenguin » Thu Aug 15, 2024 11:35 pm
That still doesn't mean that LD is successfully enabled when running inside the Docker container.
Randy Magnum
#7 Post by Randy Magnum » Fri Aug 16, 2024 6:28 am
"Just checking, but does your drive support LibreDrive? AFAIK MakeMKV cannot use a host certificate to obtain a VID for AACSv2 because it doesn't have such a certificate in the first place. This is why LibreDrive support is mandatory!"
OS device name: /devisiO
Product: BO-RE BU40N
Revision: 1.03
Serial number: ############
Bus encryption fags: 17
Highest AACS version: 72
Firmware type: Patched (microcode access re-enated)
Famware versior: 1.03
BD raw metadata read: Yes Unrestricted read speed Yes
Disc Information
Label: THE GOONIES
Timestamp: 2020-05-26 12:13:59
Protection: AACS2.0/C v72
Data capacity: 58.68 Gb Disc type: 8D-ROM UHD
Number of layers: 2
Bus encryption flags: 80
"I'm not sure what you mean by "making" a variable. Can you elaborate?
You have to identify an existing sg* device using a command like lsscsi -g"
I've done this multiple ways. In my docker configuration, I've entered --device /dev/sr0 --device /dev/sg0 in the extra parameters configuration. I've created a device configuration item with /dev/sr0 and /dev/sg0.
Is there a possibility that makeMKV doesn't have the correct permissions to access _private_data.tar. This seems like the behaviour I'm seeing. I've deleted it and restarted MakeMKV to force a download.
segfaulted
#8 Post by segfaulted » Fri Aug 16, 2024 8:36 am
I've tried out the docker image and it looks like a networking issue. Auto-updates aren't working from inside the container (yes, the checkbox is On) but they are working on the native linux host. If I copy an existing _private_data.tar to the container's /config/data folder, that allows a disc to decrypt in docker.
Randy Magnum
#9 Post by Randy Magnum » Fri Aug 16, 2024 12:25 pm
"I've tried out the docker image and it looks like a networking issue. Auto-updates aren't working from inside the container (yes, the checkbox is On) but they are working on the native linux host. If I copy an existing _private_data.tar to the container's /config/data folder, that allows a disc to decrypt in docker."
I was curious so I copied the _private_data.tar from my Mac to my Unraid box. Still not working.
segfaulted
#10 Post by segfaulted » Mon Aug 19, 2024 6:43 pm
I think I've found a fix for the network problem. On the "docker run" command, put in -e INSTALL_PACKAGES=curl as an additional option. If that works, you should see MakeMKV log messages like "Downloading latest SDF" and "Downloading latest HK" the next time you load a disc.
