Dump submitted - Furiosa: A Mad Max Saga 4K
EventDriven
#1 Post by EventDriven » Wed Aug 07, 2024 8:04 pm
Dump file submitted for "Furiosa: A Mad Max Saga" 4K
MKB20_v77_Furiosa-_A_Mad_Max_Saga_F45C.tgz
Ralph P.
Re: Dump submitted - Furiosa: A Mad Max Saga 4K
#2 Post by Ralph P. » Thu Aug 08, 2024 11:54 am
Greetings,
I submitted this one via email and uploaded it to GD. FYI.
Regards,
Brian6751
#3 Post by Brian6751 » Thu Aug 08, 2024 7:16 pm
dump submitted
MKB20_v77_Furiosa-_A_Mad_Max_Saga_6178
MrPenguin
#4 Post by MrPenguin » Thu Aug 08, 2024 11:18 pm
The latest KEYDB.cfg file contains this entry:
0x80B1235A62B42B5F5180178FE134DAFD3475A70A = FURIOSA_A_MAD_MAX_SAGA (Furiosa: A Mad Max Saga) | D | 2024-06-24
Does installing this file in MakeMKV's data directory (i.e. same directory where MakeMKV wrote your dump file) allow MakeMKV to unlock your disk?
Ralph P.
#5 Post by Ralph P. » Fri Aug 09, 2024 2:02 pm
Greetings,
I can confirm that it is now working using KEYDB.
Thanks you!
Brian6751
#6 Post by Brian6751 » Fri Aug 09, 2024 2:55 pm
@MrPenguin
FYI - I received your PM but apparently have noe posted enough to be allowed to respond(?)
Brian6751
#7 Post by Brian6751 » Fri Aug 09, 2024 7:23 pm
dump submitted
newest keydb.cfg file opened this one for me
ArcadiaHumanoid
#8 Post by ArcadiaHumanoid » Tue Aug 13, 2024 8:07 am
I have just submitted MKB20_v77_Furiosa-_A_Mad_Max_Saga_AA60.tgz
Latest keydb.cfg didn't seem to work on this one.
Chris01992
#9 Post by Chris01992 » Tue Aug 13, 2024 11:19 am
UK Version submitted: MKB20_v77_Furiosa-_A_Mad_Max_Saga_AA60.tgz
(Not yet in KEYDB.cfg file)
sykoryzen
#10 Post by sykoryzen » Tue Aug 13, 2024 3:59 pm
Uk version of Furiosa:
How do i use the file to get it to work please ?
scorp508
#11 Post by scorp508 » Tue Aug 13, 2024 4:20 pm
MakeMKV downloaded a new keydb just now but still didn't open my F45C disc. I wonder if it didn't get the latest latest one. :)
MakeMKV v1.17.7 win(x64-release) started
Using LibreDrive mode (v06.3 id=0FA242DD4D0B)
Downloading latest HK to //xxx.xxx.xxx.xxx/Data/Media/Movies ...
Saved AACS dump file as //xxx.xxx.xxx.xxx/Data/Media/Movies/MKB20_v77_Furiosa-_A_Mad_Max_Saga_F45C.tgz
MrPenguin
#12 Post by MrPenguin » Tue Aug 13, 2024 4:27 pm
MakeMKV doesn't download the KEYDB.cfg file. You need to do that, and then install it correctly as described above. MakeMKV only downloads its own "hashed keys" automatically. The KEYDB.cfg file is just an alternative database that it can read, if available.
Toker
#13 Post by Toker » Tue Aug 13, 2024 4:29 pm
FindVUK and KEYDB.cfg file worked for me (USA).
scorp508
#14 Post by scorp508 » Tue Aug 13, 2024 4:32 pm
Ah thank you for the clarification. To date I hadn't had to use that method, but will give it a shot. :)
*edit: That worked perfectly.*
tulsamatthews
#15 Post by tulsamatthews » Tue Aug 13, 2024 8:38 pm
Amazon Steelbook: MKB20_v77_Furiosa-_A_Mad_Max_Saga_F45C
submitted
