Dump submitted - The Bikeriders 4K
EventDriven
Post by EventDriven » Wed Aug 07, 2024 8:06 pm
Dump submitted for "The Bikeriders" 4K
MKB20_v77_The_Bikeriders_63A0.tgz
Ralph P.
Re: Dump submitted - The Bikeriders 4K
Post by Ralph P. » Thu Aug 08, 2024 4:48 pm
Greetings,
I submitted this one via email as well as loading it on GD.
Regards,
mhalter81
Post by mhalter81 » Sat Aug 10, 2024 1:34 pm
Anybody have any luck yet with this one? DeUHD can decrypt but apparently my disc has errors, so I'm waiting for MakeMKV so I can just try the main title portion of the disc.
mhalter81
Post by mhalter81 » Sat Aug 10, 2024 6:50 pm
Working using latest keydb.cfg!!!
mdeguzman
Post by mdeguzman » Sat Sep 28, 2024 10:10 pm
how do you use the "Dump"? Sorry for the ignorance. And thanks for the help
MrPenguin
Post by MrPenguin » Sat Sep 28, 2024 10:34 pm
As a rule, you email it to svq@makemkv.com and then post a message to this thread containing the dump's full name.
See UHD FAQ.
While waiting for your dump file to be processed, you can also try downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV. MakeMKV can use KEYDB.cfg as an alternate key database, should it not find a key inside its own "hashed key" database.
MrLarry
Post by MrLarry » Mon Oct 21, 2024 11:33 pm
Still no luck for me.
Emailed this one about a week ago. Have tried a new keyed.cfg and still no luck.
MKB20_v77_The_Bikeriders_2656.tgz
