Fall Guy Dumps Sent
omk1980
Re: Fall Guy Dumps Sent
#16 Post by omk1980 » Wed Jul 31, 2024 10:41 pm
working now!
Toby2k
#17 Post by Toby2k » Fri Aug 02, 2024 4:43 am
German Disc is working
#18 Post by MartyMcNuts » Tue Aug 06, 2024 4:42 am
Dumps submitted for both the Theatrical version and Extended Cut discs from the Aussie Steelbook Edition.
Theatrical: MKB20_v77_FALLGUY_UPK1_D1BC
Extended Cut: MKB20_v77_FALLGUY_UPK50_2994
UHDRip1337
#19 Post by UHDRip1337 » Thu Aug 08, 2024 3:56 pm
MKB20_v77_The_Fall_Guy_-_Extended_Cut_DDE4 sent
#20 Post by MartyMcNuts » Wed Aug 14, 2024 8:43 am
MartyMcNuts wrote: Tue Aug 06, 2024 4:42 am Dumps submitted for both the Theatrical version and Extended Cut discs from the Aussie Steelbook Edition.
Both of these are working now after today's update.
darthtye
#21 Post by darthtye » Mon Sep 09, 2024 11:34 pm
Just want to 2nd that updating to newest version fixed issue even if change log said "Version bump, no changes". Something must have changed.
youley
#22 Post by youley » Mon Dec 30, 2024 7:24 pm
Dump sent
MKB20_v77_FALLGUY_UPK1_AB16: Fall Guy Theatrical Cut
MrPenguin
#23 Post by MrPenguin » Tue Dec 31, 2024 11:29 am
youley wrote: Mon Dec 30, 2024 7:24 pm MKB20_v77_FALLGUY_UPK1_AB16: Fall Guy Theatrical Cut
Have you tried copying the latest KEYDB.cfg file into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?
youley
#24 Post by youley » Sat Jan 04, 2025 9:43 pm
Now working in MakeMKV, and with keydb.cfg
Toxillo
#25 Post by Toxillo » Mon May 18, 2026 3:41 pm
I have the UHD Extended Cut (FALLGUY_UPK50) of Fall Guy and the Verbatim 43888 (LG BU40N inside) but I can't get the main playlist off the disc. I have the most recent keydb.cfg which fixed the decryption errors and enabled me to get all the short stuff off. But for the main playlist it eventually shows a hash error, around 26GB in.
I saw someone who had the same issue with the same drive fix it by getting a different USB-C cable. Is that something worth trying? Unfortunately, I don't know the specs of the cables I have lying around.
The drive itself is pretty new, I only got it in February and it had no problems with the UHD Oppenheimer.
Has anyone had a similar issue with the Verbatim 43888/LG BU40N and managed to fix it?
#26 Post by dcoke22 » Mon May 18, 2026 11:31 pm
Toxillo wrote: Mon May 18, 2026 3:41 pm I have the UHD Extended Cut (FALLGUY_UPK50) of Fall Guy and the Verbatim 43888 (LG BU40N inside) but I can't get the main playlist off the disc. I have the most recent keydb.cfg which fixed the decryption errors and enabled me to get all the short stuff off. But for the main playlist it eventually shows a hash error, around 26GB in.
A hash check error generally means the drive is having trouble reading a spot on the disc. The disc might be dirty, even if it is brand new and just out of the package. A gentle cleaning is often helpful. Sometimes a drive might need more power than it is currently getting. This is sometimes a problem with portable, USB powered drives like your BU40N.
