Dump submitted - Furiosa: A Mad Max Saga 4K
EventDriven
Dump file submitted for "Furiosa: A Mad Max Saga" 4K
MKB20_v77_Furiosa-_A_Mad_Max_Saga_F45C.tgz
Ralph P.
Re: Dump submitted - Furiosa: A Mad Max Saga 4K
Greetings,
I submitted this one via email and uploaded it to GD. FYI.
Regards,
Regards,
Brian6751
dump submitted
MKB20_v77_Furiosa-_A_Mad_Max_Saga_6178
MrPenguin
The latest KEYDB.cfg file contains this entry:EventDriven wrote: Wed Aug 07, 2024 8:04 pm Dump file submitted for "Furiosa: A Mad Max Saga" 4K
0x80B1235A62B42B5F5180178FE134DAFD3475A70A = FURIOSA_A_MAD_MAX_SAGA (Furiosa: A Mad Max Saga) | D | 2024-06-24-
Ralph P.
Greetings,
I can confirm that it is now working using KEYDB.
Thanks you!
Thanks you!
Brian6751
@MrPenguin
FYI - I received your PM but apparently have noe posted enough to be allowed to respond(?)
Brian6751
newest keydb.cfg file opened this one for me
ArcadiaHumanoid
I have just submitted MKB20_v77_Furiosa-_A_Mad_Max_Saga_AA60.tgz
Latest keydb.cfg didn't seem to work on this one.
Chris01992
UK Version submitted: MKB20_v77_Furiosa-_A_Mad_Max_Saga_AA60.tgz
(Not yet in KEYDB.cfg file)
sykoryzen
Uk version of Furiosa:
How do i use the file to get it to work please ?
scorp508
MakeMKV downloaded a new keydb just now but still didn't open my F45C disc. I wonder if it didn't get the latest latest one.MrPenguin wrote: Thu Aug 08, 2024 11:18 pm The latest KEYDB.cfg file contains this entry:Does installing this file in MakeMKV's data directory (i.e. same directory where MakeMKV wrote your dump file) allow MakeMKV to unlock your disk?Code: Select all
MakeMKV v1.17.7 win(x64-release) started
Using LibreDrive mode (v06.3 id=0FA242DD4D0B)
Downloading latest HK to //xxx.xxx.xxx.xxx/Data/Media/Movies ...
Saved AACS dump file as //xxx.xxx.xxx.xxx/Data/Media/Movies/MKB20_v77_Furiosa-_A_Mad_Max_Saga_F45C.tgz
MrPenguin
MakeMKV doesn't download the KEYDB.cfg file. You need to do that, and then install it correctly as described above. MakeMKV only downloads its own "hashed keys" automatically. The KEYDB.cfg file is just an alternative database that it can read, if available.scorp508 wrote: Tue Aug 13, 2024 4:20 pmMakeMKV downloaded a new keydb just now but still didn't open my F45C disc. I wonder if it didn't get the latest latest one.MrPenguin wrote: Thu Aug 08, 2024 11:18 pm The latest KEYDB.cfg file contains this entry:Does installing this file in MakeMKV's data directory (i.e. same directory where MakeMKV wrote your dump file) allow MakeMKV to unlock your disk?Code: Select all
0x80B1235A62B42B5F5180178FE134DAFD3475A70A = FURIOSA_A_MAD_MAX_SAGA (Furiosa: A Mad Max Saga) | D | 2024-06-24![]()
Toker
FindVUK and KEYDB.cfg file worked for me (USA).
scorp508
Ah thank you for the clarification. To date I hadn't had to use that method, but will give it a shot.MrPenguin wrote: Tue Aug 13, 2024 4:27 pm MakeMKV doesn't download the KEYDB.cfg file. You need to do that, and then install it correctly as described above. MakeMKV only downloads its own "hashed keys" automatically. The KEYDB.cfg file is just an alternative database that it can read, if available.
*edit: That worked perfectly.*
tulsamatthews
Amazon Steelbook: MKB20_v77_Furiosa-_A_Mad_Max_Saga_F45C
submitted
submitted
