Dump submitted - Furiosa: A Mad Max Saga 4K
EventDriven
Post by EventDriven »
Dump file submitted for "Furiosa: A Mad Max Saga" 4K
MKB20_v77_Furiosa-_A_Mad_Max_Saga_F45C.tgz
Ralph P.
Re: Dump submitted - Furiosa: A Mad Max Saga 4K
Post by Ralph P. »
Greetings,
I submitted this one via email and uploaded it to GD. FYI.
Regards,
Brian6751
Post by Brian6751 »
dump submitted
MKB20_v77_Furiosa-_A_Mad_Max_Saga_6178
MrPenguin
Post by MrPenguin »
EventDriven wrote:
Wed Aug 07, 2024 8:04 pm
The latest KEYDB.cfg file contains this entry:
0x80B1235A62B42B5F5180178FE134DAFD3475A70A = FURIOSA_A_MAD_MAX_SAGA (Furiosa: A Mad Max Saga) | D | 2024-06-24
Does installing this file in MakeMKV's data directory (i.e. same directory where MakeMKV wrote your dump file) allow MakeMKV to unlock your disk?
Ralph P.
Post by Ralph P. »
Greetings,
I can confirm that it is now working using KEYDB.
Thanks you!
Brian6751
Post by Brian6751 »
@MrPenguin
FYI - I received your PM but apparently have noe posted enough to be allowed to respond(?)
Brian6751
Post by Brian6751 »
Brian6751 wrote:
Thu Aug 08, 2024 7:16 pm
dump submitted
newest keydb.cfg file opened this one for me
ArcadiaHumanoid
Post by ArcadiaHumanoid »
I have just submitted MKB20_v77_Furiosa-_A_Mad_Max_Saga_AA60.tgz
Latest keydb.cfg didn't seem to work on this one.
Chris01992
Post by Chris01992 »
UK Version submitted: MKB20_v77_Furiosa-_A_Mad_Max_Saga_AA60.tgz
(Not yet in KEYDB.cfg file)
sykoryzen
Post by sykoryzen »
Uk version of Furiosa:
How do i use the file to get it to work please ?
scorp508
Post by scorp508 »
MrPenguin wrote:
Thu Aug 08, 2024 11:18 pm
MakeMKV downloaded a new keydb just now but still didn't open my F45C disc. I wonder if it didn't get the latest latest one. :)
MakeMKV v1.17.7 win(x64-release) started
Using LibreDrive mode (v06.3 id=0FA242DD4D0B)
Downloading latest HK to //xxx.xxx.xxx.xxx/Data/Media/Movies ...
Saved AACS dump file as //xxx.xxx.xxx.xxx/Data/Media/Movies/MKB20_v77_Furiosa-_A_Mad_Max_Saga_F45C.tgz
MrPenguin
Post by MrPenguin »
scorp508 wrote:
Tue Aug 13, 2024 4:20 pm
MakeMKV doesn't download the KEYDB.cfg file. You need to do that, and then install it correctly as described above. MakeMKV only downloads its own "hashed keys" automatically. The KEYDB.cfg file is just an alternative database that it can read, if available.
Toker
Post by Toker »
FindVUK and KEYDB.cfg file worked for me (USA).
scorp508
Post by scorp508 »
MrPenguin wrote:
Tue Aug 13, 2024 4:27 pm
Ah thank you for the clarification. To date I hadn't had to use that method, but will give it a shot. :)
*edit: That worked perfectly.*
tulsamatthews
Post by tulsamatthews »
Amazon Steelbook: MKB20_v77_Furiosa-_A_Mad_Max_Saga_F45C
submitted
