Scott Pilgrim 4K UHD UPK75 2024 Dump Submitted B9A3 code
BluraySlayer69
Post by BluraySlayer69 » Sun Jul 28, 2024 1:25 pm
Scott Pilgrim 4K UHD UPK75 2024 Dump Submitted. New copy purchased 7/2024 from Amazon during Prime days. shows up as "The volume key is unknown for this disc - video can't be decrypted
Failed to open disc" B9A3 Dump Code
Last edited by BluraySlayer69 on Sun Jul 28, 2024 10:10 pm, edited 1 time in total.
Re: Scott Pilgrim 4K UHD UPK75 2024 Dump Submitted
Post by Woodstock » Sun Jul 28, 2024 9:20 pm
And the 4-character ID code on the dump file was ???
BluraySlayer69
Post by BluraySlayer69 » Sun Jul 28, 2024 10:08 pm
B9A3 is the code on the Dump File
MrPenguin
Re: Scott Pilgrim 4K UHD UPK75 2024 Dump Submitted B9A3 code
Post by MrPenguin » Mon Jul 29, 2024 10:37 am
BluraySlayer69 wrote: Sun Jul 28, 2024 1:25 pm Scott Pilgrim 4K UHD UPK75 2024 Dump Submitted. New copy purchased 7/2024 from Amazon during Prime days. shows up as "The volume key is unknown for this disc - video can't be decrypted
MakeMKV can also use KEYDB.cfg as an alternative key database, if you copy this file into MakeMKV's data directory. (This is the same directory which MakeMKV writes its .tgz dump files into.) Does installing KEYDB.cfg help you unlock your disk?
BluraySlayer69
Post by BluraySlayer69 » Mon Jul 29, 2024 4:05 pm
No I already have the latest file in that location and no change. I've had that work for the new 2024 civilwar movie but nothing on this version of scott pilgrim.
erocl
Post by erocl » Tue Jul 30, 2024 3:23 pm
I am having the exact same problem. I also purchased the 4K disc during the Amazon Prime sale.
I submitted the dump file to svq@makemkv.com on July 25th, but haven't heard anything back.
erocl
Post by erocl » Tue Aug 06, 2024 4:20 pm
I just tried again. MakeMKV downloaded a new file (decryption?) and now it's working.
