Dump Submitted: Heathers 4K
mysterysup
Post by mysterysup » Thu Aug 01, 2024 2:32 am
Dump Submitted: "MKB20_v77_Heathers_UHD_17B4"
mysterysup
Re: Dump Submitted: Heathers 4K
Post by mysterysup » Fri Aug 02, 2024 2:45 pm
Working now using the KEYDB from FindVUK
cerealpimp73
Post by cerealpimp73 » Tue Aug 06, 2024 2:01 am
I'm not having any luck with this one.
MrPenguin
Post by MrPenguin » Tue Aug 06, 2024 6:55 am
Is your dump's filename exactly "MKB20_v77_Heathers_UHD_17B4", or is the four-digit tag at the end different? You definitely need to email your dump to svq@makemkv.com if the tags are different, although there's no harm in emailing it anyway.
Having said that, dumps sent to svq@makemkv.com have always taken an unpredictable length of time to process. See these instructions to install an alternative KEYDB.cfg database while you're waiting. (Think of it as a fallback plan...)
cerealpimp73
Post by cerealpimp73 » Tue Aug 06, 2024 6:28 pm
My TGZ file is different:
MKB20_v77_HEATHERS_-_4K_UHD_17B4.tgz
I submitted (e-mailed) a dump for it.
MrPenguin
Post by MrPenguin » Tue Aug 06, 2024 7:10 pm
Curiously, the tag at the end of yours is also 17B4, which I would have thought meant that it is effectively the same! And that the KEYDB.cfg file would therefore work for you :?.
(I wish I understood how MakeMKV calculated that four-character tag... :cry:)
