V for Vendetta Dump submitted
extranet
#1 Post by extranet » Fri Aug 02, 2024 4:37 pm
Hi
Dump for MKB20_v76_V_for_Vendetta_F8D3 submitted.
Thanks.
MrPenguin
Re: V for Vendetta Dump submitted
#2 Post by MrPenguin » Sun Aug 04, 2024 11:08 am
extranet wrote: Fri Aug 02, 2024 4:37 pm Dump for MKB20_v76_V_for_Vendetta_F8D3 submitted.
The latest KEYDB.cfg file contains these entries, which have VUKs:
0x34B4576BF1E6931C24815DD8D59C805C61D5FFC2 = V_FOR_VENDETTA (V for Vendetta) | D | 2020-08-18
0x003E4DE09EF5D2B12B541365D1B2F17765BA4E7D = V_FOR_VENDETTA (V for Vendetta) | D | 2020-09-09
0x289D8200C34207B281A1187F2D4B6C958D5F19C3 = V_FOR_VENDETTA [V for Vendetta 4K Ultra HD] | D | 2020-09-09
0xE4ADD78AD573C582EDE6BA668B36D050B5179293 = V_FOR_VENDETTA [V for Vendetta 4K Ultra HD] | D | 2020-09-09
And these entries, which only have Unit Keys:
0x518E422235F43DA7F52BE5CDF09BAA03C7CA5FA3 = V_FOR_VENDETTA (V for Vendetta) | D | 2020-08-18
0x5616CBCFF659199402F84B1415C6335AA53F98DF = V_FOR_VENDETTA (V for Vendetta) | D | 2020-09-09
MakeMKV needs an entry with a VUK, and so I would say the odds favor KEYDB working for you :). (See these instructions.)
extranet
#3 Post by extranet » Sun Aug 04, 2024 1:10 pm
Yep working now. Thanks :)
billqs
#4 Post by billqs » Mon Aug 12, 2024 1:38 am
Mine worked without a problem but it identified two titles each of 67GB. Does anyone know if title 00 or 05 is the correct one? This is the USA WB UHD Bluray release. Thanks!
cas206
#5 Post by cas206 » Mon Aug 12, 2024 2:48 pm
billqs wrote: Mon Aug 12, 2024 1:38 am Mine worked without a problem but it identified two titles each of 67GB. Does anyone know if title 00 or 05 is the correct one? This is the USA WB UHD Bluray release. Thanks!
See the FAQ for "Which playlist do I choose?"
viewtopic.php?f=1&t=24388
Most of the ones I've run into have play with commentary on or off options that cause the two titles.
billqs
#6 Post by billqs » Mon Aug 12, 2024 3:44 pm
Thanks! :)
subsonic9701
#7 Post by subsonic9701 » Mon Mar 17, 2025 8:12 pm
Unable to decrypt new disc. Attaching file as instructed.
MKB20_v76_V_FOR_VENDETTA_A42B.tgz
(1.91 MiB) Downloaded 622 times
MrPenguin
#8 Post by MrPenguin » Tue Mar 18, 2025 12:23 am
subsonic9701 wrote: Mon Mar 17, 2025 8:12 pm Unable to decrypt new disc. Attaching file as instructed.
Habe you tried downloading the latest KEYDB.cfg file, copying it into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV?
subsonic9701
#9 Post by subsonic9701 » Tue Mar 18, 2025 1:18 pm
Yep, that worked. Thanks!
