Le Samourai UHD - Criterion Collection
by96$
Post by by96$ » Fri Jul 12, 2024 8:03 pm
I just submitted the TGZ file for the newly released Le Samourai in 4K by Criterion.
by96$
Re: Le Samourai UHD - Criterion Collection
Post by by96$ » Sat Aug 03, 2024 3:38 pm
I have submitted the TGZ file twice but it still won't rip. It has been three weeks. Are others having delays?
MrPenguin
Post by MrPenguin » Sat Aug 03, 2024 3:56 pm
by96$ wrote: Sat Aug 03, 2024 3:38 pm I have submitted the TGZ file twice but it still won't rip. It has been three weeks. Are others having delays?
The latest KEYDB.cfg file contains these entries:
0xC05B32CC05A309D5F713213153E45B841E007AB0 = LE SAMOURAI (LE SAMOURAÏ) | D | 2024-05-06
0x49ECC848D3CA98CBB44AAF124597F15556BF3408 = LE SAMOURAI (LE SAMOURAÏ) | D | 2024-05-07
0x4F2F2C31D285252FF1B9458DF55AA375862F149C = LE_SAMOURAI (BLU-RAY UHD) | D | 2023-07-08
Does your disk unlock if you add this file to MakeMKV's data directory (i.e. the same directory where MakeMKV writes its dump files), and then restart MakeMKV? See these instructions.
by96$
Post by by96$ » Sat Aug 03, 2024 4:15 pm
Thank you! I have never downloaded the key file manually before. I will see if it works.
I am wondering if the Criterion Collection UHD is different form the 2023 one you listed. I think the Criterion disc was just released.
MrPenguin
Post by MrPenguin » Sat Aug 03, 2024 4:23 pm
by96$ wrote: Sat Aug 03, 2024 4:15 pm Thank you! I have never downloaded the key file manually before. I will see if it works.
The KEYDB is just an alternative key database that MakeMKV is able to read, and can (sometimes) be a useful fallback plan if MakeMKV's own database is being a bit slow ;).
by96$
Post by by96$ » Sat Aug 03, 2024 4:31 pm
Yeah, it didn't work. I think the one I am trying to rip is different. But thanks for helping out!!
MrPenguin
Post by MrPenguin » Sat Aug 03, 2024 6:07 pm
by96$ wrote: Sat Aug 03, 2024 4:31 pm Yeah, it didn't work. I think the one I am trying to rip is different. But thanks for helping out!!
The KEYDB.cfg actually contains keys for three different versions of this disk. Check PM?
