MakeMKV FLAC Rip
K@mpfH@mster
MakeMKV FLAC Rip
#1 Post by K@mpfH@mster » Thu Aug 01, 2024 11:16 am
Hi, I downloaded the flatpak version of MakeMKV. It works generally but if I select the FLAC preset it stops after several minutes without doing/creating anything. It works with DEFAULT so i guess it has something to do with Flac converting.
Re: MakeMKV FLAC Rip
#2 Post by dcoke22 » Thu Aug 01, 2024 3:04 pm
MakeMKV uses ffmpeg underneath to do audio conversion. On the Windows and Mac versions of MakeMKV, a tiny version of ffmpeg ships with the binary. On Linux, it uses whatever ffmpeg is on the system. There are all kinds of reports of trouble with MakeMKV using ffmpeg 6. This interaction between MakeMKV and ffmpeg is most likely the root cause of the behavior you're seeing.
K@mpfH@mster
#3 Post by K@mpfH@mster » Thu Aug 01, 2024 5:03 pm
But how can I solve this?
hartie95
#4 Post by hartie95 » Sat Aug 31, 2024 9:58 pm
For me locally I fixed it by shipping ffmpeg 4.4.4 with the flatpak, made a pull request for it, which should contain a link to test the change, in case you don't want to wait for a merge:
https://github.com/flathub/com.makemkv.MakeMKV/pull/90
K@mpfH@mster
#5 Post by K@mpfH@mster » Sun Sep 01, 2024 5:34 am
THX, I hope there will be a final FLATPAK soon
K@mpfH@mster
#6 Post by K@mpfH@mster » Sun Sep 08, 2024 11:33 am
Hey, I just recieved a Flatpak update and with this FLAC Rip worked, now I need to find out how to rip rip from disc instead from ISO
#7 Post by mike admin » Mon Sep 30, 2024 1:44 pm
fixed in 1.17.8
K@mpfH@mster
#8 Post by K@mpfH@mster » Mon Sep 30, 2024 3:28 pm
When will it be released?
MrPenguin
#9 Post by MrPenguin » Mon Sep 30, 2024 8:26 pm
It has already been released... :mrgreen:
K@mpfH@mster
#10 Post by K@mpfH@mster » Mon Sep 30, 2024 10:10 pm
But not as FLATPAK
#11 Post by Woodstock » Tue Oct 01, 2024 12:43 am
That would depend on whoever generates the flatpak, which isn't the author...
