MakeMKV FLAC Rip
K@mpfH@mster
MakeMKV FLAC Rip
Hi, I downloaded the flatpak version of MakeMKV. It works generally but if I select the FLAC preset it stops after several minutes without doing/creating anything. It works with DEFAULT so i guess it has something to do with Flac converting.
Re: MakeMKV FLAC Rip
MakeMKV uses ffmpeg underneath to do audio conversion. On the Windows and Mac versions of MakeMKV, a tiny version of ffmpeg ships with the binary. On Linux, it uses whatever ffmpeg is on the system. There are all kinds of reports of trouble with MakeMKV using ffmpeg 6. This interaction between MakeMKV and ffmpeg is most likely the root cause of the behavior you're seeing.
K@mpfH@mster
But how can I solve this?
hartie95
For me locally I fixed it by shipping ffmpeg 4.4.4 with the flatpak, made a pull request for it, which should contain a link to test the change, in case you don't want to wait for a merge:
https://github.com/flathub/com.makemkv.MakeMKV/pull/90
K@mpfH@mster
THX, I hope there will be a final FLATPAK soon
K@mpfH@mster
Hey, I just recieved a Flatpak update and with this FLAC Rip worked, now I need to find out how to rip rip from disc instead from ISO
- Contact:
fixed in 1.17.8
K@mpfH@mster
When will it be released?
MrPenguin
It has already been released...
K@mpfH@mster
But not as FLATPAK
That would depend on whoever generates the flatpak, which isn't the author...
