MKB20_v77_FALLGUY_UPK75_F03E
MKB20_v77_FALLGUY_UPK77_56A0
Keydb.cfg works
Fall Guy Dumps Sent
jkosharek
Re: Fall Guy Dumps Sent
For me my Fall Guy UHD (MKB20_v77_The_Fall_Guy_F03E.tgz) says 'The volume key is unknown for this disc - video can't be decrypted'niteflyr wrote: Tue Jul 23, 2024 6:14 pm MKB20_v77_FALLGUY_UPK75_F03E
Keydb.cfg works
Where can download a copy of a Keydb.cfg that will decrypt Fall Guy UHD ?
WAYFLIX
MKB20_v77_The_Fall_Guy_9C5E here. (Walmart Steelbook)
Keydb.cfg is not working for this one yet.
MrPenguin
From here. See these instructions.jkosharek wrote: Wed Jul 24, 2024 2:27 pm Where can download a copy of a Keydb.cfg that will decrypt Fall Guy UHD ?
Toad King
New extended edition dump (from Walmart steelbook) sent.
MKB20_v77_The_Fall_Guy_-_Extended_Cut_B52C
Both the theatrical (F03E) and extended cuts in my copy work with keydb.
ZZorrander
I had the same file dump and found the instructions for the key db file. It now works.
androgenix
Dumps sent
MKB20_v77_FALLGUY_UPK75_F03E: Fall Guy Theatrical
MKB20_v77_FALLGUY_UPK77_0610: Fall Guy Extended
F03E is in keydb but 0610 is not as of today
MrPenguin
These are the two "FALLGUY_UPK77" entries so far:androgenix wrote: Mon Jul 29, 2024 11:26 am Dumps sent
0xC5B613D96A4CDD6C5074750A859934FED4723439 = FALLGUY_UPK77 (The Fall Guy - Extended Cut) | D | 2024-04-22
0x98627B399F0C8C085F815D9439BA9C45AF568B20 = FALLGUY_UPK77 (The Fall Guy - Extended Cut) | D | 2024-04-22
Rockevangel
I am a total noob here. What do I have to do to be able to rip the movie?
Are you trying to rip the 4K UHD of Fall Guy? Is MakeMKV giving an error? Please post your error here.Rockevangel wrote: Mon Jul 29, 2024 11:16 pm I am a total noob here. What do I have to do to be able to rip the movie?
There's a UHD FAQ you can read through.
I answered a similar question recently: https://forum.makemkv.com/forum/viewtopic.php?p=156849#p156849
Buhli
Hello everyone
I tried to copy the extended 4K version of "The Fall Guy" today. Unfortunately without success. Error message: The volume key for the DVD/Blu-ray is unknown - the video cannot be decrypted.
I have sent the dump "MKB20_v77_The_Fall_Guy_-_Extended_Cut_E2C6" to svq@makemkv.com. Is there anything else I need to do? I have also already downloaded the keydb.cfg. Unfortunately that didn't work either. But I'm also not 100% sure what exactly I need to do with this file
Many thanks
Greetings
Buhli
Many thanks
Greetings
Buhli
Toby2k
Dumps sent:
German Disc
German Disc
solatech
Dump sent:
MKB20_v77_The_Fall_Guy_-_Extended_Cut_0610-
tbrady3742@aol.com
I got mine from Gruv, when I tried to rip it it says failed to open.Toad King wrote: Wed Jul 24, 2024 9:26 pm New extended edition dump (from Walmart steelbook) sent.
MrPenguin
See these instructions for how to install KEYDB.cfg. Basically, you copy the file into the same directory where MakeMKV wrote your .tgz dump file, and then restart MakeMKV.Buhli wrote: Tue Jul 30, 2024 3:15 pm I have also already downloaded the keydb.cfg. Unfortunately that didn't work either. But I'm also not 100% sure what exactly I need to do with this file
Think of it as a fall-back plan
