Pioneer BDR-XD07UHD - The Fall Guy 4K Extended
SeaLight
#1 Post by SeaLight » Tue Jul 23, 2024 3:40 pm
I've been previously able to rip UHD discs (Jurassic World: Dominion, Maverick, etc.) but I just went to rip The Fall Guy's extended version in 4K and I just got a message that I haven't previously seen and it won't let me rip it. Any help here?
Saved AACS dump file as /Users/eric/Library/MakeMKV/MKB20_v77_The_Fall_Guy_-_Extended_Cut_56A0.tgz
OS device name: /dev/rdisk4
Manufacturer: PIONEER
Product: BD-RW BDR-XD07U
Revision: 1.05
Serial number: [redacted]
Firmware date: 2023-01-06
Bus encryption flags: 13
Highest AACS version: 77
Drive platform: Pioneer RS8D31
Firmware version: ID05
Disc Information
Label: FALLGUY_UPK77
Timestamp: 2024-05-06 11:32:49
Protection: AACS2.0/C v77
Data capacity: 92.89 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
Re: Pioneer BDR-XD07UHD - The Fall Guy 4K Extended
#2 Post by Billycar11 » Tue Jul 23, 2024 3:46 pm
SeaLight wrote: Tue Jul 23, 2024 3:40 pm I've been previously able to rip UHD discs (Jurassic World: Dominion, Maverick, etc.) but I just went to rip The Fall Guy's extended version in 4K and I just got a message that I haven't previously seen and it won't let me rip it. Any help here?
Revision: 1.05
Disc Information
Number of layers: 3
you were never able to rip UHD discs on that FW
did you just update if so sadly you ruined your drive
i still have pioneers with old FW if you want one see below
brey749
#3 Post by brey749 » Thu Jul 25, 2024 6:14 pm
I just received and tried ripping The Fall Guy, extended, and also received an error. Not sure where to go from here...
Saved AACS dump file as ...[redacted]
MakeMKV Info:
Product: BD-RE BP60NB10
Revision: 1.00
Firmware date: 2117-11-21 17:20
Highest AACS version: 78
Firmware version: 1.00
Disc Information
Label: FALLGUY_UPK75
Timestamp: 2024-05-03 16:53:49
Data capacity: 92.83 Gb
Number of layers: 3
#4 Post by d00zah » Thu Jul 25, 2024 6:43 pm
brey749 wrote: Thu Jul 25, 2024 6:14 pm I just received and tried ripping The Fall Guy, extended, and also received an error. Not sure where to go from here...
MakeMKV Info:
Revision: 1.00
Disc Information
Number of layers: 3
Suggested reading... UHD FAQ
MakeMKV says that "the volume key is unknown for this disc"?
MakeMKV produces an AACS .tgz dump file whenever you try to open a disc for which the key is unknown, and will report that the dump has been created. Email the dump file to svq@makemkv.com.
I submitted a dump, how long does it take?
Once submitted, the turnaround can be pretty fast, between 12 to 48 hours. However, it can also sometimes take several days or longer.
When you submit a dump, ensure that:
- You are using the latest version of MakeMKV.
- You are using a LibreDrive-enabled drive (be it "friendly" or "official", but it must be LibreDrive enabled).
- You have "Enable Internet access" enabled in Preferences (in the General tab), so that MakeMKV will check for updated keys when you try to open the disc again.
- You are opening the original disc (not a backup, not ISO).
- You are opening the disc using a real disc drive natively (no elby clonedrive, no vmware, no dvdfab or discsoft virtual, etc).
brey749
#5 Post by brey749 » Thu Jul 25, 2024 7:57 pm
d00zah wrote: Thu Jul 25, 2024 6:43 pm Suggested reading... UHD FAQ
Perfect. Thanks for the help! I just submitted the AACS dump file for both versions - appreciate you taking the time to direct me to the right spot.
#6 Post by d00zah » Thu Jul 25, 2024 8:05 pm
brey749 wrote: Thu Jul 25, 2024 7:57 pm
You're welcome. Enjoy!
darthtye
#7 Post by darthtye » Sun Jul 28, 2024 11:28 pm
Seeing similar issues with 4k purchased from amazon I guess I'll wait for next update and try again thanks
MrPenguin
#8 Post by MrPenguin » Mon Jul 29, 2024 1:34 pm
darthtye wrote: Sun Jul 28, 2024 11:28 pm Seeing similar issues with 4k purchased from amazon I guess I'll wait for next update and try again thanks
Why aren't you posting this in the Fall Guy 4K disks thread?
darthtye
#9 Post by darthtye » Mon Nov 10, 2025 7:39 pm
MrPenguin wrote: Mon Jul 29, 2024 1:34 pm
This is the thread that came up when I searched for fall guy thanks for the link to other thread. I also acknowledge responding over a year later is futile but I don't like to leave things hanging.
