The Boy and the Heron 4K Dump File
Re: The Boy and the Heron 4K Dump File
Post by SamuriHL »
Did you restart makemkv after doing that?
Sent from my SM-S928U1 using Tapatalk
sephirothkefka
Post by sephirothkefka »
SamuriHL wrote:
Fri Jul 12, 2024 2:10 am
Indeed I did. Still nothing.
Post by SamuriHL »
Well this is why I have Xreveal installed as well. Point it to the keydb and let it decrypt then makemkv will (begrudgingly) open it fine.
sephirothkefka
SamuriHL wrote:
Fri Jul 12, 2024 2:30 am
I got it now! Working well!
MrPenguin
Post by MrPenguin »
sephirothkefka wrote:
Fri Jul 12, 2024 1:09 am
The newest keydb.cfg has the hash for the file but it still isn't working for me. Any idea whats going on? keydb is in the right place but it still isn't working.
The KEYDB.cfg file now has this disk's unit key, but not its volume unique key (VUK). (Well, not yet anyway.) And MakeMKV needs the VUK to decrypt the disk. Or failing that, you can ask MakeMKV to decrypt the disk using Xreveal instead.
immutableme
Post by immutableme »
Still not working for me, on Mac so don't have xreveal
immutableme
Fri Jul 12, 2024 2:36 am
How did you get it working?
toastnips
Post by toastnips »
immutableme wrote:
Fri Jul 12, 2024 5:02 pm
I am wondering that as well. I have a Windows computer and installed it, pointed it to the KEYDB.cfg file, and tried a lot of different things but xreveal refuses to recognize any disc I put in to the drive. Looks like some of us will have to continue to wait for it to work. The disc is in the keydb, it's just that it is missing something that makemkv uses.
sephirothkefka
toastnips wrote:
Fri Jul 12, 2024 10:51 pm
I have a Pioneer BDR-211UBK and all I did was properly point it to the KEYDB.cfg and it just worked. Libredrive was enabled in the options. once successful it prompted a region code screen which I did A and it worked.
toastnips
Post by toastnips »
Sat Jul 13, 2024 10:08 am
When you start xreveal and makemkv, if you put in the disc, does it automatically come up? I am guessing it is because I have a flashed LG drive, but xreveal sees the drive, it just doesn't see any disc I put in it.
Post by SamuriHL »
Close MakeMKV....
1) Insert disc
2) If Xreveal is not running, start it
3) Let Xreveal see and decrypt the disc
4) THEN load MakeMKV
P.S. Make sure the drive is enabled in Xreveal settings, as well.
toastnips
Post by toastnips »
SamuriHL wrote:
Sat Jul 13, 2024 4:13 pm
Close MakeMKV....
1) Insert disc
Interesting. Uninstalling and reinstalling it seems to work no problem now. Thank you! If anyone else is reading this to use this method, you may have to point it to the KEYDB.cfg file for it to work, or replace the one in the default folder.
immutableme
Close MakeMKV....
1) Insert disc
Thank you, much appreciated. Was the impetus to get me to spin up a windows VM with xreveal so I learned a lot from this process.
Brian6751
Post by Brian6751 »
dump file submitted
MKB20_v77_The_Boy_and_the_Heron_2A12
mbarnstijn
Post by mbarnstijn »
@SamuriHL, my friend, could you send this confused member of a "gone missing" other forum a PM? Sorry to contact this way, can't do PMs yet here, haven't posted enough. Do you remember my email?
--michael
