Phantoms 4k - Dump Submitted
Epitaph
Post by Epitaph »
MKB20_v77_Phantoms_8D06.tgz
rhett7660
Re: Phantoms 4k - Dump Submitted
Post by rhett7660 »
Awesome... I did the same... Didn't see your post before I sent mine in. And now we wait!! :D
MrPenguin
Post by MrPenguin »
Epitaph wrote:
Mon Jul 01, 2024 4:51 pm
The latest KEYDB.cfg file contains this entry:
0x9AC008232BF20D80CCA86B6C0ACB503CFA4DC1EF = PHANTOMS (Phantoms) | D | 2024-05-10
Does this work? See these instructions.
rhett7660
Post by rhett7660 »
So I have read through the various threads and it seems most are all for windows... do you happen to know where this file would go on a Mac? Or how I can force Makemkv do an update?
Post by SamuriHL »
It's the directory that MakeMKV outputs the tgz dump files. Rename it to KEYDB.cfg (it is case sensitive) and restart MakeMKV.
rhett7660 wrote:
Fri Jul 12, 2024 12:54 am
you should be able to see it in the makemkv settings its called the data directory under general
