Dune Part 2 Dump Submitted
Rocket
Re: Dune Part 2 Dump Submitted
#46 Post by Rocket » Tue Jul 09, 2024 9:53 am
I have just submitted MKB20_v77_Dune-_Part_Two_95C0.tgz. As I have seen, this version has
not been submitted.
MrPenguin
#47 Post by MrPenguin » Tue Jul 09, 2024 10:01 am
Rocket wrote: Tue Jul 09, 2024 9:53 am I have just submitted MKB20_v77_Dune-_Part_Two_95C0.tgz. As I have seen, this version has
not been submitted.
Have you tried installing the latest KEYDB.cfg file into your .MakeMKV directory (which is where MakeMKV wrote your .tgz dump file)?
EricLille
#48 Post by EricLille » Wed Jul 10, 2024 6:42 pm
Hello
I’m in France and i bought Dune 2 in uhd disc. I tried to rip it and makemkv doesn’t succeed to open the disc.
I sent the tgz file to svq@makemkv.com. it still doesn’t work
I updated the keydb. It doesn’t work. Where should i place this file in the makemkv directory ?
Thanks for your advices
MrPenguin
#49 Post by MrPenguin » Wed Jul 10, 2024 7:00 pm
EricLille wrote: Wed Jul 10, 2024 6:42 pm Hello
Copy the latest KEYDB.cfg file into the same directory where MakeMKV writes its .tgz dump files, and then restart MakeMKV. If you're using MacOS or Linux then you should also ensure that the file name is KEYDB.cfg and not keydb.cfg, because the file-system is case-sensitive.
What is the full name of your tgz dump file please?
Fu2chN
#50 Post by Fu2chN » Wed Jul 10, 2024 7:21 pm
Hi, same problem as EricLille.
"MKB20_v77_Dune-_Part_Two_95C0.tgz"
EricLille
#51 Post by EricLille » Thu Jul 11, 2024 4:55 am
Yes it’s the same tgz name as Fu2chN
EricLille
#52 Post by EricLille » Thu Jul 11, 2024 4:57 am
MrPenguin wrote: Wed Jul 10, 2024 7:00 pm
I copied the keydb.cfg in the tgz files directory. It doesn’t work
Are there other solutions ?
MrPenguin
#53 Post by MrPenguin » Thu Jul 11, 2024 7:40 am
EricLille wrote: Thu Jul 11, 2024 4:57 am I copied the keydb.cfg in the tgz files directory. It doesn’t work
"Waiting for Mike" is the obvious solution, although it's also worth checking the KEYDB.cfg file periodically while you wait. The KEYDB.cfg file is constantly updated by people across the Internet, and so you might be lucky with a newer title because someone else could reasonably add your disk while you're waiting.
EricLille
#54 Post by EricLille » Thu Jul 11, 2024 7:04 pm
I already had the same problem with other uhd discs. i asked my retailer to change the disc and this new one worked immediately with makemkv. How do you explain that ?
MrPenguin
#55 Post by MrPenguin » Thu Jul 11, 2024 7:16 pm
EricLille wrote: Thu Jul 11, 2024 7:04 pm I already had the same problem with other uhd discs. i asked my retailer to change the disc and this new one worked immediately with makemkv. How do you explain that ?
There are two possible explanations:
  1. Mike had computed the key for your disk while you were busy exchanging it.
  2. Your new disk has a different "master disk" to your original disk, and MakeMKV already knew your new disk's key.
From your perspective, it probably doesn't matter which of these explanations is true.
Rocket
#56 Post by Rocket » Fri Jul 12, 2024 6:32 am
MrPenguin wrote: Tue Jul 09, 2024 10:01 am
not been submitted.
Thank you for your suggestion! For the moment I have time, so I'll wait a few days. But it's good to know this workaround.
EricLille
#57 Post by EricLille » Fri Jul 12, 2024 10:25 am
I have updated the keydb this morning and it worked.
Thank you !
MrPenguin
#58 Post by MrPenguin » Fri Jul 12, 2024 10:32 am
EricLille wrote: Fri Jul 12, 2024 10:25 am I have updated the keydb this morning and it worked.
Thanks for confirming that KEYDB.cfg now contains a key for the 95C0 variant.
EricLille
6th sense uhd disc - issue to open the disc
#59 Post by EricLille » Thu Dec 19, 2024 9:28 am
Hi, i sent you a mail about the sixth sense uhd bluray that the sofware can't open. Could you take a look to my problem ?
Eric
MrPenguin
Re: 6th sense uhd disc - issue to open the disc
#60 Post by MrPenguin » Thu Dec 19, 2024 12:58 pm
EricLille wrote: Thu Dec 19, 2024 9:28 am Hi, i sent you a mail about the sixth sense uhd bluray that the sofware can't open. Could you take a look to my problem ?
This thread is about "Dune: Part 2". Wouldn't this thread be a better place to ask?
