Phantoms 4k - Dump Submitted
MKB20_v77_Phantoms_8D06.tgz
Re: Phantoms 4k - Dump Submitted
Awesome... I did the same... Didn't see your post before I sent mine in. And now we wait!!
The latest KEYDB.cfg file contains this entry:
0x9AC008232BF20D80CCA86B6C0ACB503CFA4DC1EF = PHANTOMS (Phantoms) | D | 2024-05-10Re: Phantoms 4k - Dump Submitted
So I have read through the various threads and it seems most are all for windows... do you happen to know where this file would go on a Mac? Or how I can force Makemkv do an update?
It's the directory that MakeMKV outputs the tgz dump files. Rename it to KEYDB.cfg (it is case sensitive) and restart MakeMKV.
you should be able to see it in the makemkv settings its called the data directory under generalrhett7660 wrote: Fri Jul 12, 2024 12:54 am So I have read through the various threads and it seems most are all for windows... do you happen to know where this file would go on a Mac? Or how I can force Makemkv do an update?
