Dump submitted for Andor Season 1
Stryker412
Post by Stryker412 » Sun Apr 28, 2024 10:28 pm
Oddly enough, the first and third disc worked fine, but not the second. I submitted a dump for that disc.
BigMike_3
Re: Dump submitted for Andor Season 1
Post by BigMike_3 » Mon Apr 29, 2024 4:44 am
I had the same thing on mine. First and Third work, but I can't open the second. Let us know if it starts to work for you.
Stryker412
Post by Stryker412 » Tue Apr 30, 2024 10:51 am
I just tried this morning. Nothing as of yet.
DESTROYER_325
Post by DESTROYER_325 » Sun Jul 07, 2024 6:34 pm
How do I access these dumps?
Post by Woodstock » Sun Jul 07, 2024 8:27 pm
The dump would be created during the rip, and the path to it would be reported by MakeMKV when it is generated.
MrPenguin
Post by MrPenguin » Sun Jul 07, 2024 8:45 pm
FWIW if you're having difficulty, the latest KEYDB.cfg contains these entries:
0xB70AA57B4A01A92E015C5F33448937B989BEF80E = ANDOR_COMPLETE_FIRST_SEASON_D2 (Andor: The Complete First Season Disc 2 - Ultra HD™) | D | 2024-03-13
0x9CA4F5DFFBA4B1639E12887C1FB44C28B70A74A2 = ANDOR_COMPLETE_FIRST_SEASON_D2 (Andor: The Complete First Season Disc 2 - Ultra HD™) | D | 2024-03-14
0x5AB206E21921FC420E51B4529744F98976645817 = ANDOR_COMPLETE_FIRST_SEASON_D2 (Andor: The Complete First Season Disc 2 - Ultra HD™) | D | 2024-03-01
Does any of these match your disk? See these instructions.
PhantomPhoenixForce
Post by PhantomPhoenixForce » Fri Apr 18, 2025 9:47 pm
submitted the following dump files:
MKB20_v77_Andor-_The_Complete_First_Season_Disc_1_6D77.tgz
MKB20_v77_Andor-_The_Complete_First_Season_Disc_2_B73D.tgz
MKB20_v77_Andor-_The_Complete_First_Season_Disc_3_F679.tgz
MrPenguin
Post by MrPenguin » Fri Apr 18, 2025 10:23 pm
Failing that, could you also make your TGZ dump files available here please? E.g. as attachments, or by providing a download link? These would help The Powers That KEYDB support your disks.
lfoust
Post by lfoust » Sat Jul 19, 2025 5:57 pm
I was able to successfully rip this set. Here is how it layed out for me: https://thediscdb.com/series/star-wars- ... eelbook-4k
