Twister 4K Dump Submitted
Ralph P.
Post by Ralph P. »
MKB20_v77_Twister_19AC
Ralph P.
Re: Twister 4K Dump Submitted
Post by Ralph P. »
Greetings,
I have heard from several people with the same version (as I have) that they have successfully ripped Twister. I tried again today and still get the same "no volume key/failed to open error". Any ideas?
Post by SamuriHL »
There's a version of it in the keydb file. You can try that and see if it works for your version.
Sent from my SM-S928U1 using Tapatalk
clarkss12
Post by clarkss12 »
I am having the same issue with my newly arrived "Twister 4k"
Edit: The newest keydb file dated 7/7/2024 worked. Now my drive is ripping this disc.
thank you.
triplerinse
Post by triplerinse »
clarkss12 wrote: Sun Jul 07, 2024 6:17 pm I am having the same issue with my newly arrived "Twister 4k"
thank you.
where are you finding this file? on the forms here or somewhere else
MrPenguin
Post by MrPenguin »
triplerinse wrote: Mon Jul 08, 2024 11:38 pm where are you finding this file? on the forms here or somewhere else
Definitely somewhere else, inside a ZIP file ;). See these instructions.
triplerinse
MrPenguin wrote: Mon Jul 08, 2024 11:56 pm
i have seen this thread before about Download FindVUK 1.72. but i have stayed away from clicking on random links on the internet. what kind of file is it?
MrPenguin
Post by MrPenguin »
triplerinse wrote: Tue Jul 09, 2024 12:16 am i have seen this thread before about Download FindVUK 1.72. but i have stayed away from clicking on random links on the internet. what kind of file is it?
The somewhere else link leads to the "FindVUK Online Database" web page, from where you can download a ZIP file containing the latest KEYDB.cfg. And that's just a text file.
FindVUK.exe itself is a Windows command line application which maintains your KEYDB.cfg. You don't need FindVUK, although it does help.
Post by SamuriHL »
Highly recommended to have FindVUK as it has a synchronize function. If you look there's instructions on modifying the bat file for synchronize to automagically copy your KEYDB.cfg file after it syncs with FindVUK to your MakeMKV data directory so it always stays up to date with the latest keys. You can see coopervid's instructions on that with this link:
viewtopic.php?p=145704#p145704
This will keep you up to date.
triplerinse
SamuriHL wrote: Tue Jul 09, 2024 12:28 am Highly recommended to have FindVUK as it has a synchronize function. If you look there's instructions on modifying the bat file for synchronize to automagically copy your KEYDB.cfg file after it syncs with FindVUK to your MakeMKV data directory so it always stays up to date with the latest keys. You can see coopervid's instructions on that with this link:
I'm assuming you have downloaded the file from https://forum.doom9.org/showthread.php?t=172472 and have not seen any malice files from it?
Post by SamuriHL »
Not only have I downloaded the file, I've written my own tools on top of it. Yea, it's clean and works as it claims. If you have DVDFab and a compatible drive, it'll even extract your unit keys for you. Doesn't help with MakeMKV but that's what the tool was originally designed for. KeyDB syncing is just one of the features of that amazing tool.
triplerinse
SamuriHL wrote: Tue Jul 09, 2024 12:43 am Not only have I downloaded the file, I've written my own tools on top of it. Yea, it's clean and works as it claims. If you have DVDFab and a compatible drive, it'll even extract your unit keys for you. Doesn't help with MakeMKV but that's what the tool was originally designed for. KeyDB syncing is just one of the features of that amazing tool.
sorry
i have used mkv for so long. MKV and dvd fab basically do the same thing don't they, so if it is decrypted by dvd fab why would you need the key for something like vlc? Sorry if i sound stupid lol
Post by SamuriHL »
You wouldn't necessarily. But maybe you like helping those who don't have DVDFab by uploading the unit keys to the keydb...Just like those who've uploaded keys for the title you're looking for have helped others by uploading the keys. :)
clarkss12
Post by clarkss12 »
thank you.
I used this link...... http://fvonline-db.bplaced.net/
triplerinse
clarkss12 wrote: Tue Jul 09, 2024 2:22 am
thank you.
thanks
