DRACULAE1931_UPK1 [Dump]
outland
Post by outland »
Submitted file MKB20_v76_Dracula_AD2F.tgz
Dracula (1931)
outland
Re: DRACULAE1931_UPK1 [Dump]
Post by outland »
Still can't open this one. Anyone else that have tried this version of Dracula?
Overhead5469
Post by Overhead5469 »
I also have problems with this disc. I submitted the dump about 2 weeks ago and it seems to match the one you have submitted.
Did you get it open or do you still have the same problem?
MakeMKV v1.17.7 win(x64-release) started
Using LibreDrive mode (v01.0 id=489CDFD6D392)
Downloading latest HK to C:\Users\xxx/.MakeMKV ...
Saved AACS dump file as C:\Users\xxx/.MakeMKV/MKB20_v76_Dracula_AD2F.tgz
MrPenguin
Post by MrPenguin »
Overhead5469 wrote: Tue Aug 27, 2024 4:38 am I also have problems with this disc. I submitted the dump about 2 weeks ago and it seems to match the one you have submitted.
The latest KEYDB.cfg file contains these entries:
0x05D0C051E4AFF47A987FAB3F1FCB1B9C106BA94D = DRACULAE1931_UPK1 (Dracula) | D | 2021-08-02
0xC36E242EE63BE8325389A50737E7AB96398F87C9 = DRACULAE1931_UPK1 (Dracula) | D | 2021-08-02
Does copying this file into MakeMKV's data directory (i.e. where MakeMKV also writes its TGZ dump files) and restarting MakeMKV help?
Overhead5469
MrPenguin wrote: Wed Aug 28, 2024 7:36 am
That did the trick, thank you.
As a sanity check I checked that I have internet access enabled and tried again without the manually downloaded keydb.cfg but it didn't work.
