New Taxi Driver 4k Dump submitted
clarkss12
Post by clarkss12 »
Just received new UHD disc of Taxi driver in 4k.
Name of file submitted. MKB20_v77_Taxi_Driver_B978
Getting this message "The volume key is unknown for this disc - video can't be decrypted: Failed to open disc"
This is the movie that I purchased. Was a pre-order
Sony Pictures
Taxi Driver (4K Ultra HD + Blu-ray) (Steelbook), Sony Pictures, Drama
Re: New Taxi Driver 4k Dump summited
Lots of information... except for the NAME of the file submitted, which includes a 4-digit code that lets people know which version was submitted. If the version you submitted is the same one they have, no need for a separate file to be sent; if not, they would need to submit theirs as well.
MrPenguin
Re: New Taxi Driver 4k Dump submitted
Post by MrPenguin »
clarkss12 wrote: Sun Jun 30, 2024 8:01 pm Name of file submitted. MKB20_v77_Taxi_Driver_B978
The latest KEYDB.cfg file contains these two entries:
0x96DED66C69422A1C793128B992A00C2628DCEE4E = TAXI_DRIVER (Taxi Driver) | D | 2024-05-02
0xEE2A3B8C9C63CEF3164660227170BF9A21928FA4 = TAXI_DRIVER [Taxi Driver 4K Ultra HD] | D | 2021-07-12
Could one of these match your disk? See these instructions.
clarkss12
Post by clarkss12 »
Yes, my hash matches the first one. 96DED66C69422A1C793128B992A00C2628DCEE4E. Will download the latest file and see how that works.
clarkss12
Post by clarkss12 »
I downloaded the KEYDB.cfg file, but can't find where to put it. I cannot find where the original KEYDB.cfg file is located on my PC.
MrPenguin
Post by MrPenguin »
clarkss12 wrote: Tue Jul 02, 2024 8:07 pm I downloaded the KEYDB.cfg file, but can't find where to put it. I cannot find where the original KEYDB.cfg file is located on my PC.
I doubt your PC has any "original" KEYDB.cfg file to find ;). It's an "optional extra resource", not part of a default installation of MakeMKV.
You put the new KEYDB.cfg file in the same directory where MakeMKV wrote its MKB20_XXX_YYY.tgz file. (The exact directory is configurable in MakeMKV's preferences, but you don't need to change it.) And then restart MakeMKV, just to be sure.
FireByTrial
Post by FireByTrial »
MrPenguin wrote: Tue Jul 02, 2024 7:44 am
Thank You! fixed my issue with the 4k I just received :D
