Purple Rain UHD
Braider31
Purple Rain UHD
#1 Post by Braider31 » Tue Jun 25, 2024 7:08 am
I just submitted the dump file for Purple Rain UHD - MKB20_v77_Purple_Rain_ABA4.tgz
MrPenguin
Re: Purple Rain UHD
#2 Post by MrPenguin » Tue Jun 25, 2024 1:43 pm
And while you're waiting, the KEYDB.cfg file already contains these two disks:
0x5FA37CFF332E7ECA2372D02AE069B79835DB6E64 = PURPLE_RAIN (Purple Rain) | D | 2024-05-03
0xC558ECE5606B2CD56FA6D0299E9BBF5EDD26A5E5 = PURPLE_RAIN (Purple Rain) | D | 2024-04-10
Does either of these match yours?
rdgrimes
Re: Purple Rain UHD
#3 Post by rdgrimes » Wed Jun 26, 2024 2:48 am
Worked for me this afternoon.
Braider31
Re: Purple Rain UHD
#4 Post by Braider31 » Wed Jun 26, 2024 6:48 am
Mine is still not working, possibly because it's the UK disc?
MrPenguin
Re: Purple Rain UHD
#5 Post by MrPenguin » Wed Jun 26, 2024 9:25 am
Have you installed the KEYDB.cfg file into the correct place? You need to put it into the same directory that MakeMKV writes its .tgz dump files. And filenames on MacOS and Linux are also case-sensitive, so you need to call it exactly KEYDB.cfg and not keydb.cfg.
Braider31
Re: Purple Rain UHD
#6 Post by Braider31 » Wed Jun 26, 2024 4:58 pm
Thanks, I followed your instructions but I still couldn't get it to work. Appreciate your help though, cheers. Edited to add, after typing this message I tried it one more time and it worked! Thanks again.
MrPenguin
Re: Purple Rain UHD
#7 Post by MrPenguin » Wed Jun 26, 2024 5:42 pm
Did you restart MakeMKV this time? I don't know at what point MakeMKV parses the KEYDB.cfg file... ;)
Braider31
Re: Purple Rain UHD
#8 Post by Braider31 » Wed Jun 26, 2024 6:17 pm
I did restart it, but also when I downloaded the KEYDB file again it came in a zip file which it hadn't before. Either way, you were super helpful and I got there in the end, somehow...
