Purple Rain UHD
Braider31
Purple Rain UHD
I just submitted the dump file for Purple Rain UHD - MKB20_v77_Purple_Rain_ABA4.tgz
MrPenguin
Re: Purple Rain UHD
And while you're waiting, the KEYDB.cfg file already contains these two disks:Braider31 wrote: Tue Jun 25, 2024 7:08 am I just submitted the dump file for Purple Rain UHD - MKB20_v77_Purple_Rain_ABA4.tgz
0x5FA37CFF332E7ECA2372D02AE069B79835DB6E64 = PURPLE_RAIN (Purple Rain) | D | 2024-05-03
0xC558ECE5606B2CD56FA6D0299E9BBF5EDD26A5E5 = PURPLE_RAIN (Purple Rain) | D | 2024-04-10
rdgrimes
Re: Purple Rain UHD
Worked for me this afternoon.
Braider31
Re: Purple Rain UHD
Mine is still not working, possibly because it's the UK disc?
MrPenguin
Re: Purple Rain UHD
Have you installed the KEYDB.cfg file into the correct place? You need to put it into the same directory that MakeMKV writes its .tgz dump files. And filenames on MacOS and Linux are also case-sensitive, so you need to call it exactly KEYDB.cfg and not keydb.cfg.Braider31 wrote: Wed Jun 26, 2024 6:48 am Mine is still not working, possibly because it's the UK disc?
Braider31
Re: Purple Rain UHD
Thanks, I followed your instructions but I still couldn't get it to work. Appreciate your help though, cheers. Edited to add, after typing this message I tried it one more time and it worked! Thanks again.MrPenguin wrote: Wed Jun 26, 2024 9:25 amHave you installed the KEYDB.cfg file into the correct place? You need to put it into the same directory that MakeMKV writes its .tgz dump files. And filenames on MacOS and Linux are also case-sensitive, so you need to call it exactly KEYDB.cfg and not keydb.cfg.Braider31 wrote: Wed Jun 26, 2024 6:48 am Mine is still not working, possibly because it's the UK disc?
MrPenguin
Re: Purple Rain UHD
Did you restart MakeMKV this time? I don't know at what point MakeMKV parses the KEYDB.cfg file...Braider31 wrote: Wed Jun 26, 2024 4:58 pm Edited to add, after typing this message I tried it one more time and it worked! Thanks again.
Braider31
Re: Purple Rain UHD
I did restart it, but also when I downloaded the KEYDB file again it came in a zip file which it hadn't before. Either way, you were super helpful and I got there in the end, somehow...
