keydb.cfg
Re: keydb.cfg
Try putting the keydb.cfg file into MakeMKV's data directory, and renaming it to KEYDB.cfg for good measure.testt wrote: Mon Jun 24, 2024 1:27 pm i am trying to rip the mandalorian ultra hd but it says no key but when i download keydb.cfg and put it in aacs it still says no key so i am wondering what am i doing wrong or where should i put the key
The data directory is the same directory where MakeMKV writes its _private_data.tar file, and also its MKB20_XXX_YYYY.tgz dump files.
Re: keydb.cfg
when i put it in the same location as movie dump location it still does not work as i get this error
'SPTI:\Device\CdRom0'
DEBUG: Code 3 at )&=Q6'431iOhNZcp)d:213131686
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:121264395
DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:213130789
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom0'
DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766
DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:213131709
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..03F to device 'SPTI:\Device\CdRom0'
DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:213131686
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom0'
DEBUG: Code 1 at )&=Q6'431iOhNZcp)d:213131709
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..07F to device 'SPTI:\Device\CdRom0'
DEBUG: Code 1 at )&=Q6'431iOhNZcp)d:213131686
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0BF to device 'SPTI:\Device\CdRom0'
DEBUG: Code 2 at )&=Q6'431iOhNZcp)d:213131709
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0BF to device 'SPTI:\Device\CdRom0'
DEBUG: Code 2 at )&=Q6'431iOhNZcp)d:213131686
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0FF to device 'SPTI:\Device\CdRom0'
DEBUG: Code 3 at )&=Q6'431iOhNZcp)d:213131709
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0FF to device 'SPTI:\Device\CdRom0'
DEBUG: Code 1 at )&=Q6'431iOhNZcp)d:213130789
DEBUG: Code 2 at )&=Q6'431iOhNZcp)d:213130789
DEBUG: Code 3 at )&=Q6'431iOhNZcp)d:213130789
DEBUG: Code 4 at )&=Q6'431iOhNZcp)d:213130789
Saved AACS dump file as C:\Users\thoma/.MakeMKV/MKB20_v77_THE_MANDALORIAN_SEASON_1_DISC_1_4004.tgz
DEBUG: Code 0 at *?fa{/h[G&00(#,E:213132721
DEBUG: Code 0 at *?fa{/h[G&00(#,E:213131341
Failed to open discRe: keydb.cfg
Did you rename is as told to KEYDB.cfg? All uppercase before the dot and cfg?testt wrote: Mon Jun 24, 2024 5:17 pm when i put it in the same location as movie dump location it still does not work as i get this errorCode: Select all
'SPTI:\Device\CdRom0' DEBUG: Code 3 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0' Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:121264395 DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:213130789 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..03F to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 1 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..07F to device 'SPTI:\Device\CdRom0' DEBUG: Code 1 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0BF to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 2 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0BF to device 'SPTI:\Device\CdRom0' DEBUG: Code 2 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0FF to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 3 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0FF to device 'SPTI:\Device\CdRom0' DEBUG: Code 3 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0' Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:121264395 DEBUG: Code 1 at )&=Q6'431iOhNZcp)d:213130789 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..03F to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 1 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..07F to device 'SPTI:\Device\CdRom0' DEBUG: Code 1 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0BF to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 2 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0BF to device 'SPTI:\Device\CdRom0' DEBUG: Code 2 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0FF to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 3 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0FF to device 'SPTI:\Device\CdRom0' DEBUG: Code 3 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0' Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:121264395 DEBUG: Code 2 at )&=Q6'431iOhNZcp)d:213130789 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..03F to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 1 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..07F to device 'SPTI:\Device\CdRom0' DEBUG: Code 1 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0BF to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 2 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0BF to device 'SPTI:\Device\CdRom0' DEBUG: Code 2 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0FF to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 3 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0FF to device 'SPTI:\Device\CdRom0' DEBUG: Code 3 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0' Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:121264395 DEBUG: Code 3 at )&=Q6'431iOhNZcp)d:213130789 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..03F to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 1 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..07F to device 'SPTI:\Device\CdRom0' DEBUG: Code 1 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0BF to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 2 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0BF to device 'SPTI:\Device\CdRom0' DEBUG: Code 2 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0FF to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 3 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0FF to device 'SPTI:\Device\CdRom0' DEBUG: Code 3 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0' Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:121264395 DEBUG: Code 4 at )&=Q6'431iOhNZcp)d:213130789 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..03F to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 1 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..07F to device 'SPTI:\Device\CdRom0' DEBUG: Code 1 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0BF to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 2 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0BF to device 'SPTI:\Device\CdRom0' DEBUG: Code 2 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0FF to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 3 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0FF to device 'SPTI:\Device\CdRom0' DEBUG: Code 3 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0' Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:121264395 DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:213130789 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..03F to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 1 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..07F to device 'SPTI:\Device\CdRom0' DEBUG: Code 1 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0BF to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 2 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0BF to device 'SPTI:\Device\CdRom0' DEBUG: Code 2 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0FF to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 3 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0FF to device 'SPTI:\Device\CdRom0' DEBUG: Code 3 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0' Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:121264395 DEBUG: Code 1 at )&=Q6'431iOhNZcp)d:213130789 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..03F to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 1 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..07F to device 'SPTI:\Device\CdRom0' DEBUG: Code 1 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0BF to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 2 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0BF to device 'SPTI:\Device\CdRom0' DEBUG: Code 2 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0FF to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 3 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0FF to device 'SPTI:\Device\CdRom0' DEBUG: Code 3 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0' Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:121264395 DEBUG: Code 2 at )&=Q6'431iOhNZcp)d:213130789 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..03F to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 1 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..07F to device 'SPTI:\Device\CdRom0' DEBUG: Code 1 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0BF to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 2 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0BF to device 'SPTI:\Device\CdRom0' DEBUG: Code 2 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0FF to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 3 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0FF to device 'SPTI:\Device\CdRom0' DEBUG: Code 3 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0' Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:121264395 DEBUG: Code 3 at )&=Q6'431iOhNZcp)d:213130789 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..03F to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 1 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..07F to device 'SPTI:\Device\CdRom0' DEBUG: Code 1 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0BF to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 2 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0BF to device 'SPTI:\Device\CdRom0' DEBUG: Code 2 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0FF to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 3 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0FF to device 'SPTI:\Device\CdRom0' DEBUG: Code 3 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0' Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:121264395 DEBUG: Code 4 at )&=Q6'431iOhNZcp)d:213130789 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..03F to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 1 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..07F to device 'SPTI:\Device\CdRom0' DEBUG: Code 1 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0BF to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 2 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0BF to device 'SPTI:\Device\CdRom0' DEBUG: Code 2 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0FF to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 3 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0FF to device 'SPTI:\Device\CdRom0' DEBUG: Code 3 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0' Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:121264395 DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:213130789 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..03F to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 1 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..07F to device 'SPTI:\Device\CdRom0' DEBUG: Code 1 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0BF to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 2 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0BF to device 'SPTI:\Device\CdRom0' DEBUG: Code 2 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0FF to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 3 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0FF to device 'SPTI:\Device\CdRom0' DEBUG: Code 3 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0' Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:121264395 DEBUG: Code 1 at )&=Q6'431iOhNZcp)d:213130789 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..03F to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 1 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..07F to device 'SPTI:\Device\CdRom0' DEBUG: Code 1 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0BF to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 2 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0BF to device 'SPTI:\Device\CdRom0' DEBUG: Code 2 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0FF to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 3 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0FF to device 'SPTI:\Device\CdRom0' DEBUG: Code 3 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0' Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:121264395 DEBUG: Code 2 at )&=Q6'431iOhNZcp)d:213130789 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..03F to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 1 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..07F to device 'SPTI:\Device\CdRom0' DEBUG: Code 1 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0BF to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 2 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0BF to device 'SPTI:\Device\CdRom0' DEBUG: Code 2 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0FF to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 3 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0FF to device 'SPTI:\Device\CdRom0' DEBUG: Code 3 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0' Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:121264395 DEBUG: Code 3 at )&=Q6'431iOhNZcp)d:213130789 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..03F to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 1 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..07F to device 'SPTI:\Device\CdRom0' DEBUG: Code 1 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0BF to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 2 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0BF to device 'SPTI:\Device\CdRom0' DEBUG: Code 2 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0FF to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 3 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0FF to device 'SPTI:\Device\CdRom0' DEBUG: Code 3 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0' Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:121264395 DEBUG: Code 4 at )&=Q6'431iOhNZcp)d:213130789 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..03F to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 1 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..07F to device 'SPTI:\Device\CdRom0' DEBUG: Code 1 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0BF to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 2 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0BF to device 'SPTI:\Device\CdRom0' DEBUG: Code 2 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0FF to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 3 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0FF to device 'SPTI:\Device\CdRom0' DEBUG: Code 3 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0' Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:121264395 DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:213130789 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..03F to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 1 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..07F to device 'SPTI:\Device\CdRom0' DEBUG: Code 1 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0BF to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 2 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0BF to device 'SPTI:\Device\CdRom0' DEBUG: Code 2 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0FF to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 3 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0FF to device 'SPTI:\Device\CdRom0' DEBUG: Code 3 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0' Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:121264395 DEBUG: Code 1 at )&=Q6'431iOhNZcp)d:213130789 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..03F to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 1 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..07F to device 'SPTI:\Device\CdRom0' DEBUG: Code 1 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0BF to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 2 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0BF to device 'SPTI:\Device\CdRom0' DEBUG: Code 2 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0FF to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 3 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0FF to device 'SPTI:\Device\CdRom0' DEBUG: Code 3 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0' Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:121264395 DEBUG: Code 2 at )&=Q6'431iOhNZcp)d:213130789 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..03F to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 1 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..07F to device 'SPTI:\Device\CdRom0' DEBUG: Code 1 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0BF to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 2 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0BF to device 'SPTI:\Device\CdRom0' DEBUG: Code 2 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0FF to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 3 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0FF to device 'SPTI:\Device\CdRom0' DEBUG: Code 3 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0' Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:121264395 DEBUG: Code 3 at )&=Q6'431iOhNZcp)d:213130789 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..03F to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 1 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..07F to device 'SPTI:\Device\CdRom0' DEBUG: Code 1 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0BF to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 2 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0BF to device 'SPTI:\Device\CdRom0' DEBUG: Code 2 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0FF to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766 DEBUG: Code 3 at )&=Q6'431iOhNZcp)d:213131709 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0FF to device 'SPTI:\Device\CdRom0' DEBUG: Code 3 at )&=Q6'431iOhNZcp)d:213131686 Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0' Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0' DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:121264395 DEBUG: Code 4 at )&=Q6'431iOhNZcp)d:213130789 Can't read AACS VID from disc - most likely current AACS host certificate is revoked by your drive Saved AACS dump file as C:\Users\thoma/.MakeMKV/MKB20_v77_THE_MANDALORIAN_SEASON_1_DISC_1_4004.tgz LibreDrive compatible drive is required to open this disc - video can't be decrypted. DEBUG: Code 0 at *?fa{/h[G&00(#,E:213132721 DEBUG: Code 0 at *?fa{/h[G&00(#,E:213131341 Failed to open disc
And do you have a flashed drive?
"LibreDrive compatible drive is required to open this disc - video can't be decrypted."
Re: keydb.cfg
yes it is as KEYDB.cfg and not the drive will not flash at all as when i click write it does nothing i think i have this drive LG BP60NB10
Re: keydb.cfg
Re: keydb.cfg
Post your makemkv drive info section it does not look like your drive is flashed or has the right firmware
Re: keydb.cfg
I second that. Post your Makemkv info.Billycar11 wrote: Mon Jun 24, 2024 8:18 pm Post your makemkv drive info section it does not look like your drive is flashed or has the right firmware
Re: keydb.cfg
are you talking about this information Drive Information
Product: BD-RE BP60NB10
Revision: 1.02
Serial number: [redacted]
Firmware date: 2121-07-08 15:56
Highest AACS version: 77
Harware support: Yes
Firmware support: No
Firmware version: 1.02
Disc Information
Label: THE_MANDALORIAN_S1_D1
Timestamp: 2023-10-17 10:36:40
Protection: AACS2.0/C v77
Data capacity: 82.21 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
and when i run sdftool flasher i get this error command produced error code 0xff056103
Revision: 1.02
Disc Information
Number of layers: 3
Re: keydb.cfg
Remove the disc from the drive & close the tray. Then try to update FW.testt wrote: Mon Jun 24, 2024 9:26 pm ...and when i run sdftool flasher i get this error command produced error code 0xff056103
Re: keydb.cfg
Revision: 1.02
Revision: 1.02
Re: keydb.cfg
yeah not flashed see guide below or email me or marty for an auto flashertestt wrote: Mon Jun 24, 2024 9:33 pm Drive Information
Revision: 1.02
Re: keydb.cfg
would the tool i have not be able to flash it if so why does it not flash it
Re: keydb.cfg
Did you try flashing after removing the disc from the drive?testt wrote: Mon Jun 24, 2024 9:36 pm would the tool i have not be able to flash it if so why does it not flash it
Re: keydb.cfg
yes i did that before but now that may have worked
it did work thanks i am wondering on why it needed to be flashed
