keydb.cfg
testt
keydb.cfg
Post by testt » Mon Jun 24, 2024 1:27 pm
i am trying to rip the mandalorian ultra hd but it says no key but when i download keydb.cfg and put it in aacs it still says no key so i am wondering what am i doing wrong or where should i put the key
MrPenguin
Re: keydb.cfg
Post by MrPenguin » Mon Jun 24, 2024 2:17 pm
testt wrote: Mon Jun 24, 2024 1:27 pm i am trying to rip the mandalorian ultra hd but it says no key but when i download keydb.cfg and put it in aacs it still says no key so i am wondering what am i doing wrong or where should i put the key
Try putting the keydb.cfg file into MakeMKV's data directory, and renaming it to KEYDB.cfg for good measure.
The data directory is the same directory where MakeMKV writes its _private_data.tar file, and also its MKB20_XXX_YYYY.tgz dump files.
testt
Re: keydb.cfg
Post by testt » Mon Jun 24, 2024 5:17 pm
when i put it in the same location as movie dump location it still does not work as i get this error
'SPTI:\Device\CdRom0'
DEBUG: Code 3 at )&=Q6'431iOhNZcp)d:213131686
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom0'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom0'
DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:121264395
DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:213130789
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom0'
DEBUG: Code 0 at (*-`xX[8}y~u)ZX31:213130766
DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:213131709
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..03F to device 'SPTI:\Device\CdRom0'
DEBUG: Code 0 at )&=Q6'431iOhNZcp)d:213131686
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom0'
DEBUG: Code 1 at )&=Q6'431iOhNZcp)d:213131709
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..07F to device 'SPTI:\Device\CdRom0'
DEBUG: Code 1 at )&=Q6'431iOhNZcp)d:213131686
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0BF to device 'SPTI:\Device\CdRom0'
DEBUG: Code 2 at )&=Q6'431iOhNZcp)d:213131709
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0BF to device 'SPTI:\Device\CdRom0'
DEBUG: Code 2 at )&=Q6'431iOhNZcp)d:213131686
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0FF to device 'SPTI:\Device\CdRom0'
DEBUG: Code 3 at )&=Q6'431iOhNZcp)d:213131709
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0FF to device 'SPTI:\Device\CdRom0'
DEBUG: Code 1 at )&=Q6'431iOhNZcp)d:213130789
DEBUG: Code 2 at )&=Q6'431iOhNZcp)d:213130789
DEBUG: Code 3 at )&=Q6'431iOhNZcp)d:213130789
DEBUG: Code 4 at )&=Q6'431iOhNZcp)d:213130789
Saved AACS dump file as C:\Users\thoma/.MakeMKV/MKB20_v77_THE_MANDALORIAN_SEASON_1_DISC_1_4004.tgz
DEBUG: Code 0 at *?fa{/h[G&00(#,E:213132721
DEBUG: Code 0 at *?fa{/h[G&00(#,E:213131341
Re: keydb.cfg
Post by Coopervid » Mon Jun 24, 2024 6:01 pm
testt wrote: Mon Jun 24, 2024 5:17 pm when i put it in the same location as movie dump location it still does not work as i get this error
Did you rename is as told to KEYDB.cfg? All uppercase before the dot and cfg?
And do you have a flashed drive?
"LibreDrive compatible drive is required to open this disc - video can't be decrypted."
testt
Re: keydb.cfg
Post by testt » Mon Jun 24, 2024 6:31 pm
yes it is as KEYDB.cfg and not the drive will not flash at all as when i click write it does nothing i think i have this drive LG BP60NB10
Re: keydb.cfg
Post by Coopervid » Mon Jun 24, 2024 6:34 pm
Re: keydb.cfg
Post by Billycar11 » Mon Jun 24, 2024 8:18 pm
Post your makemkv drive info section it does not look like your drive is flashed or has the right firmware
Re: keydb.cfg
Post by Coopervid » Mon Jun 24, 2024 8:45 pm
Billycar11 wrote: Mon Jun 24, 2024 8:18 pm Post your makemkv drive info section it does not look like your drive is flashed or has the right firmware
I second that. Post your Makemkv info.
testt
Re: keydb.cfg
Post by testt » Mon Jun 24, 2024 9:26 pm
are you talking about this information Drive Information
Product: BD-RE BP60NB10
Revision: 1.02
Serial number: [redacted]
Firmware date: 2121-07-08 15:56
Highest AACS version: 77
Harware support: Yes
Firmware support: No
Firmware version: 1.02
Disc Information
Label: THE_MANDALORIAN_S1_D1
Timestamp: 2023-10-17 10:36:40
Protection: AACS2.0/C v77
Data capacity: 82.21 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
and when i run sdftool flasher i get this error command produced error code 0xff056103
Re: keydb.cfg
Post by d00zah » Mon Jun 24, 2024 9:30 pm
testt wrote: Mon Jun 24, 2024 9:26 pm ...and when i run sdftool flasher i get this error command produced error code 0xff056103
Remove the disc from the drive & close the tray. Then try to update FW.
testt
Re: keydb.cfg
Post by testt » Mon Jun 24, 2024 9:33 pm
Revision: 1.02
Re: keydb.cfg
Post by Billycar11 » Mon Jun 24, 2024 9:35 pm
testt wrote: Mon Jun 24, 2024 9:33 pm Drive Information
Revision: 1.02
yeah not flashed see guide below or email me or marty for an auto flasher
testt
Re: keydb.cfg
Post by testt » Mon Jun 24, 2024 9:36 pm
would the tool i have not be able to flash it if so why does it not flash it
Re: keydb.cfg
Post by d00zah » Mon Jun 24, 2024 9:38 pm
testt wrote: Mon Jun 24, 2024 9:36 pm would the tool i have not be able to flash it if so why does it not flash it
Did you try flashing after removing the disc from the drive?
testt
Re: keydb.cfg
Post by testt » Mon Jun 24, 2024 9:40 pm
yes i did that before but now that may have worked
it did work thanks i am wondering on why it needed to be flashed
