Dump submitted for Withnail and I - 4K blu-ray
bayards
#1 Post by bayards » Sun Jun 23, 2024 12:34 pm
submitted 22 June 2024
Re: Dump submitted for Withnail and I - 4K blu-ray
#2 Post by Woodstock » Sun Jun 23, 2024 7:01 pm
What was the file name you submitted? The last 4 characters of the file name show are a checksum-like status of the file submitted, so that others can know if the one they need has already been sent.
MrPenguin
#3 Post by MrPenguin » Sun Jun 23, 2024 7:14 pm
Interestingly, the public KEYDB.cfg file already contains this entry:
0x806866C982B5E2DBEB92846744362ABCB571B41D = Withnail and I UHD (WITHNAIL AND I - 4K UHD) | D | 2024-03-22
And so copying the latest KEYDB.cfg file into MakeMKV's data directory may also work for you.
bayards
#4 Post by bayards » Mon Jun 24, 2024 10:06 am
MKB20_v77_WITHNAIL_AND_I_-_4K_UHD_1D66.tgz
submitted. Will try now thanks.
bayards
#5 Post by bayards » Mon Jun 24, 2024 10:12 am
Nope...still showing as unable to decode.
bayards
#6 Post by bayards » Mon Jun 24, 2024 10:17 am
MrPenguin wrote: Sun Jun 23, 2024 7:14 pm Interestingly, the public KEYDB.cfg file already contains this entry:
Grateful for any tips on how to do this? :)
MrPenguin
#7 Post by MrPenguin » Mon Jun 24, 2024 11:55 am
bayards wrote: Mon Jun 24, 2024 10:17 am
Download the KEYDB.cfg file from the link and then copy it into the same directory that MakeMKV writes the .tgz dump file into. On MacOS and Linux, the filename is case-sensitive and so should literally be KEYDB.cfg and not keydb.cfg.
This should work, provided your own disk matches the single DiscID that KEYDB.cfg contains.
bayards
#8 Post by bayards » Tue Jun 25, 2024 5:19 pm
Thank you! Ripping away as I type. :)
