Dump submitted for Withnail and I - 4K blu-ray
bayards
submitted 22 June 2024
Re: Dump submitted for Withnail and I - 4K blu-ray
What was the file name you submitted? The last 4 characters of the file name show are a checksum-like status of the file submitted, so that others can know if the one they need has already been sent.
MrPenguin
Interestingly, the public KEYDB.cfg file already contains this entry:
And so copying the latest KEYDB.cfg file into MakeMKV's data directory may also work for you.
0x806866C982B5E2DBEB92846744362ABCB571B41D = Withnail and I UHD (WITHNAIL AND I - 4K UHD) | D | 2024-03-22-
bayards
MKB20_v77_WITHNAIL_AND_I_-_4K_UHD_1D66.tgz
submitted. Will try now thanks.
bayards
Nope...still showing as unable to decode.
bayards
Grateful for any tips on how to do this?MrPenguin wrote: Sun Jun 23, 2024 7:14 pm Interestingly, the public KEYDB.cfg file already contains this entry:And so copying the latest KEYDB.cfg file into MakeMKV's data directory may also work for you.Code: Select all
MrPenguin
Download the KEYDB.cfg file from the link and then copy it into the same directory that MakeMKV writes the .tgz dump file into. On MacOS and Linux, the filename is case-sensitive and so should literally be KEYDB.cfg and not keydb.cfg.bayards wrote: Mon Jun 24, 2024 10:17 amGrateful for any tips on how to do this?MrPenguin wrote: Sun Jun 23, 2024 7:14 pm Interestingly, the public KEYDB.cfg file already contains this entry:And so copying the latest KEYDB.cfg file into MakeMKV's data directory may also work for you.Code: Select all
0x806866C982B5E2DBEB92846744362ABCB571B41D = Withnail and I UHD (WITHNAIL AND I - 4K UHD) | D | 2024-03-22![]()
This should work, provided your own disk matches the single DiscID that KEYDB.cfg contains.
bayards
Thank you! Ripping away as I type.
