Dump submitted for Withnail and I - 4K blu-ray
bayards
Post by bayards »
submitted 22 June 2024
Re: Dump submitted for Withnail and I - 4K blu-ray
What was the file name you submitted? The last 4 characters of the file name show are a checksum-like status of the file submitted, so that others can know if the one they need has already been sent.
MrPenguin
Post by MrPenguin »
Interestingly, the public KEYDB.cfg file already contains this entry:
0x806866C982B5E2DBEB92846744362ABCB571B41D = Withnail and I UHD (WITHNAIL AND I - 4K UHD) | D | 2024-03-22
And so copying the latest KEYDB.cfg file into MakeMKV's data directory may also work for you.
bayards
Post by bayards »
MKB20_v77_WITHNAIL_AND_I_-_4K_UHD_1D66.tgz
submitted. Will try now thanks.
bayards
Post by bayards »
Nope...still showing as unable to decode.
bayards
Post by bayards »
MrPenguin wrote:
Sun Jun 23, 2024 7:14 pm
Grateful for any tips on how to do this? :)
MrPenguin
Post by MrPenguin »
bayards wrote:
Mon Jun 24, 2024 10:17 am
Download the KEYDB.cfg file from the link and then copy it into the same directory that MakeMKV writes the .tgz dump file into. On MacOS and Linux, the filename is case-sensitive and so should literally be KEYDB.cfg and not keydb.cfg.
This should work, provided your own disk matches the single DiscID that KEYDB.cfg contains.
bayards
Post by bayards »
Thank you! Ripping away as I type. :)
