Getting error code 0xff05c103 when flashing LG BP50NB40 NB50
peachyplant
Post by peachyplant »
After reading a couple forms I have tried to do the recovery process I even downloaded the 1.0 version to recover but its still not letting me write tot the drive and it won't open
Re: Getting error code 0xff05c103 when flashing LG BP50NB40 NB50
peachyplant wrote: Sat Jun 15, 2024 8:29 pm After reading a couple forms I have tried to do the recovery process I even downloaded the 1.0 version to recover but its still not letting me write tot the drive and it won't open
viewtopic.php?p=94848#p94848
Follow it. Simple. Same steps for BP50NB40
peachyplant
I just want to make sure I am doing this correct since my svc is nb50 do I have to do the recovery process as if it was an NB52 also or just flash BP50NB40 (NB50) 1.03-MK
peachyplant wrote: Wed Jun 19, 2024 12:38 pm I just want to make sure I am doing this correct since my svc is nb50 do I have to do the recovery process as if it was an NB52 also or just flash BP50NB40 (NB50) 1.03-MK
Same process.
fedex_15
Post by fedex_15 »
Hi, i have the same problem here my drive is an BP50NB40 NB50 i do the process like the tread says but now i have an error code 0xff05c103. think now i have a brick
this is my drive info
Información de unidad de disco
Nombre del SO del dispositivo: D:
Fabricante: HL-DT-ST
Producto: BD-RE BP50NB40
Revisión: 1.00
Número de serie:
Fecha del firmware: 2114-09-03 17:32
Marcas de cifrado bus: 17
Highest AACS version: 16
Firmware version: 1.00
No hay disco insertado
fedex_15 wrote: Sun Feb 23, 2025 6:32 am Hi, i have the same problem here my drive is an BP50NB40 NB50 i do the process like the tread says but now i have an error code 0xff05c103. think now i have a brick
Revisión: 1.00
Número de serie:
why did you flash nb 40 fw to it?
see guide below
fedex_15
Post by fedex_15 »
Hi, thanks, beacause i made the same mistake that the other guy, and now my drive cant made a write option only read o recovery, i need a been file that make run again, the instruccions dont apply now because i cant use the write mode in de SDftool, sorry for my bad english
Thaks
fedex_15
Post by fedex_15 »
Billycar11 wrote: Sun Feb 23, 2025 1:40 pm
Revisión: 1.00
Número de serie:
see guide below
Hi, after a sveral hours now my drive is working, whit dvd and bluray but 4k uhd istn working, this is the drive info now:
Product: BD-RE BP50NB40
Revision: 1.03
Serial number:
Highest AACS version: 68
Firmware version: 1.03
what is the correct bin file for read 4k UHD
fedex_15 wrote: Mon Feb 24, 2025 2:12 am
Revisión: 1.00
Número de serie:
see guide below
Revision: 1.03
Serial number:
Email me for an auto flasher see below
scarbrtj
Post by scarbrtj »
FWIW I found that this did not allow for firmware flash, and gave the 0xff... error code:
https://www.amazon.com/dp/B001OFNLXI?re ... tle_5&th=1
But this did:
https://www.amazon.com/dp/B009JXKQ9O?re ... _title_0_0
